'97 foglight wiring
xsaylr
20
b0bber!!
I've got what's supposed to be a '97 XLT, although no pwr windows or door locks. I read that the XLT should have fog light wiring there, even if not used. Found a fog light fuse and relay in place, but what I can't seem to locate is the wiring. Does anyone have a pic of where it is in the harness?
8,375
Welcome to TRS :)
If you plan on keeping the 1997 Ranger then I would get a 1997 Ranger EVTM, like this one: https://www.ebay.com/itm/164152271317
This is the electrical manual Ford sends out every year for every model to every Ford Dealer Shop
Its part of the "Factory Shop Manual Set" and often sold separately
And when you sell your 1997 you can sell the book on ebay again, that's who is selling it now, a former 1997 Ranger owner, lol, so basically its free
EVTM has all wiring for all Ranger models and all options, wiring diagrams AND locations of these wires and ground points
Very handy to have one of these for a 24 year old vehicle
I don't have a 1997 Ranger so can't tell you where the fog light wire would be or even IF they are there
Every year would be different so the fact you have the fuse and relay is a good sign, but that may be all there is
xsaylr
20
b0bber!!
Welcome to TRS :)
Cool, I picked up the Haynes at Autozone last night and it tells me the wire colors, and that it comes from the power distribution block, but a whole bundle of wires do. Finally got a day off today so I'll see if I can find em
ericbphoto
Overlander in development
TRS 25th Anniversary
16,833
Wellford, SC
6"
You should find the light pigtails nearby behind the headlights. There should also be a switch pigtail behind the dash, close to where the factory foglight switch would have been. The dash in my 93 is different than yours. So I don't know the exact location. Mine was low on the left side of the dash and was even snapped into a little storage position built for it right behind where the switch would have been.
xsaylr
20
b0bber!!
Ok cool thanks, coincidentally I'm just digging into the dash now to replace some dash lights, so I'll be on the lookout. This thing's filthy, they must've run it thru the damn Sahara, so also cleaning as I go. From what I've seen, 93-97 should be the same style, so it's probably similar. Yeah I've been checking around the headlight wiring, that's the most logical location, just haven't spotted em yet. Hopefully they'll show up.
8,375
1997 headlight/fog light wiring below
Fog light switch on lower left, shows a 6 pin plug but only 4 wires
xsaylr
20
b0bber!!
Thanks- I have a schematic, just haven't been able to find the physical wires on the truck
xsaylr
20
b0bber!!
Hey I appreciate all the replies, whether this works out or not. So many forums seem dead anymore, like they've all moved to social media platforms. I prefer I dedicated forum, and this looks like a good 1
xsaylr
20
b0bber!!
Does your headlight switch have a setting for foglights? Or did you have a separate switch? I have neither, and I thought I'd read that the XLT should.
ericbphoto
16,833
Wellford, SC
6"
Mine had a separate switch. My 97 F150, however, had it built into the headlight switch. Rotating the switch to the "on" position allows me to pull the knob out for fog lights. I had trouble figuring that out for some reason. So I put my own separate switch in the dash on the F150.
I believe some design elements of the dash changed around 96 or 97. So I would expect your dash to be different from my 93.
xsaylr
20
b0bber!!
Ok, yeah I haven't located any wiring in the dash or around the radio either, so im just going to setup an isolated circuit, thanks
