TrexMex
- Sep 30, 2007
- 6
- Age
- 46
- Ford
- Engine Size
- 4.0L
I believe since this has to do with messing around with wiring this thread goes in this section... if not please feel free to move it.
Stuck with the tail lights upgrade... I have followed the instructions in the tech section and after two different trailer wiring kits (both from Hopkins, 48925 and 48845) I realized the brakes only kick in when the turn signal circuit is open (i.e. one of the turn signal wires is grounded or the turn signal lever is activated with the ignition switch off). Here's the thing, I found out the turn signals circuit is normally closed. So right now it's either the fancy way with relays and diodes or I'm maybe choosing the wrong trailer wiring kit, although I find it weird that two different ones operate exactly the same... any thoughts would be more than welcome.....
I also posted this message in my build thread:
http://www.therangerstation.com/forums/showthread.php?t=90271
Hope someone can help!!
