peteb1220
- Apr 9, 2024
- 0
- Crewe Va
- ranger lt
This is a real strange one!
If I disconnect battery + then reconnect and NOT start the truck wipers work fine,, until you start the engine, then the wipers stop back in there normal
off position and will not run again until battery disconnected again Need some help No apparent fuse problems checked ALL fuses One thing
different about the truck is the key rod the moves the ignition switch is broken and I have wired in a push button switch for the starter and a toggle
switch for the run connection. I did nothing to the ACC connection
The truck is only used on the farm to haul hay to goats in different fields. BTW the truck has 326,000 miles on it and still runs great except for the wipers.
Real pain in the rain driving thru fields with no wipers. I thought about splicing in a switch to the wiper motor but can't figure out the wiring.
HELP
HELP
