86 Ford Ranger 2.3L 4x4 crank pully HELP
ramzzhakim
2.3L
SO I have an 86 ford ranger, fuel injected, 2.3l, 4x4 manufactured 9/86 in dearborn. The crank pully is bent. It got messed up bad getting it off for the timing belt and I cannot, for the life of me, find another. I have been to FIVE different junkyards and I work for Orielly auto parts and thus have scoured everywhere at work and picked their brains for it. Nobody can find one.
I am willing to pay for one or if someone knows a different engine or crank pully I can use any info at all is mega appreciated. It has 2 different pullys on it but the outer im assuming is for AC, which I dont have. Attached is some pictures. I even went to the ford Dealership and they couldnt tell me anything.
I can give out a vin or any other info you guys need. Just need something. This ranger is quite sentimental to me and I want so badly to keep this engine.
http://imgur.com/a/slhYF
Spott
32
SE Idaho
This engine is really an 86, and not a replacement from a later model? I thought everything was regular V-belts at that point.
ramzzhakim
2.3L
Bought right off the lot 0 miles on it and never had an engine swap. THe IAC is on the filter housing though which pegged me as very weird but as far as I know its original engine. 300k original miles. :p
*edit spelling
ramzzhakim
2.3L
At the same time though ive looked at newer engines for the crank pully as well but they have a completely different style of pully
Spott
32
SE Idaho
If it helps, it's part #E3TZ6312A, and was used on 1984-88 Rangers (2.0 & 2.3l engines), 1986-87 Aerostars (2.3l engine) and 1987-90 Mustang LX's (2.3l engine).
Also, it's discontinued.
A junkyard is probably still your best bet.
Big Jim M
30
Austin
When I have a really weird part I need I get on eBay and find guys parting out vehicles that MIGHT have my part.
I make a proper email for the part and copy it to my computer. Then I send it to as many guys that I think might be of help.
I have never failed to get the needed part even though it was not advertised.
Big Jim
turbo91xlt
63
Goshen, NY
1992
all 4cyl rangers got a serpentine setup right from the beginning :headbang:
To the original poster, the pulley from an '89-'91 2.3 ranger should also work but you need to grab the hub assembly that it bolts to also.
ramzzhakim
2.3L
The_Epsicle
State of Boredom (Nebraska)
4.0 Pushrod V6
All hail the mighty ziptie!
That one says it's for a 2.0 not a 2.3, not sure if you noticed or if it matters at all but I thought I'd point it out.
ramzzhakim
2.3L
Overall they are 90% the same engine and so long as it fits on the crank I should be fine as far as I know, being all internally balanced and everything. This again, AS FAR AS I KNOW. Im hoping someone with vast knowledge can fly in and spew some learnin on me.
Spott
32
SE Idaho
As I posted above, the pulley for the Ranger 2.0l and 2.3l is the same, from '84-88.
The part # for the '89-91 Ranger is different than for the '84-88, so I'd be wary of getting one unless you can see and measure it yourself.
Apparently everyone missed it; I supplied a vehicle cross-reference above, that same part was used on Rangers, Aerostars, and Mustang LX's, for various years. Info pulled from HERE.
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
I don't know about SE Idaho; but, a big yard can do a parts search for you and probably/ maybe locate one. They can then get it shipped to you or them. Just an idea.
Spott
32
SE Idaho
Was that intended for me? I'm in SE Idaho, but I'm not the one looking for the pulley. I don't know where the OP is.
The biggest yard near me just went to a pure "pull it yourself" format and doesn't keep inventory databases or look for or ship parts (but they cleaned the lot up tremendously from what the previous management used to do.)
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
Sorry, I guess I can't read, I thought I was looking at the first post when I checked location and made the comment.
