84 b2
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
is that all i will need is the dizzy module and coil?
Junk Collector
Truck of Month
4,857
Rapid City SD
No you also need the wiring harness for the distributor, module and ignition coil. And a non-feedback carb unless you want to modify yours.
Good luck finding that stuff in a junkyard. Finding anything from even the 80's is impossible here. It's all been crushed.
PetesPonies
25
east coast
2.3l
Duraspark distributor, Autozone
stock coil
GM HEI module -Autozone
heat sink for module.
no wiring harness, make your own wires. Its an easy hookup.
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
thanks pete and shran our junkyards keep everything lol one junk yard is expanding cause they dont crush they just sell
kimcrwbr1
46
maplevalley WA
2.8l
I got my dizzy harness from a 84 ranger with four cyl 2.0 you can use your stock coil and you need a motorcraft/autolite carb with the 1.01 or 1.08 venturi it is on the drivers side of the float bowl in the circle.
Brownie Mobile
Williston, ND
kimcrwbr1
46
maplevalley WA
2.8l
All your doing is dissipating the heat bolt it on a large computer heat sync put some heat sync grease on the mating surface to transfer the heat.
PetesPonies
25
east coast
2.3l
You ABSOLUTELY DO NOT need the harness when using a GM HEI module. It mat be helpful, but if you can make wires and connection and do it right, you don't need to buy a harness. I'm just trying to save you a few bucks if money isn't available.
Brownie Mobile
Williston, ND
Ive heard its possible to keep the current carb is that true? if so what needs to be done?
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
brownie thanks for asking that i have bbeen gone allday and have been wanting to ask that bbut couldnt
typed on my ipod sent from computer
kimcrwbr1
46
maplevalley WA
2.8l
You can use the stock carb but you will need to make the metering block that goes on the back of the carb where the feedback solenoid is. Basically all it does is supply air to the venturi cluster the more air the leaner the mix. I allways wondered if you could just create a leak in the feedback solenoid for the same effect. I will try and find the link for the metering block.
PetesPonies
25
east coast
2.3l
IMO, not worth trying to use the stock carb. 2100s are so cheap and easy to find, easy to rebuild.
Brownie Mobile
Williston, ND
Yeah sorry about that didnt mean to jack your thread lol
509lifted
Firefighter
10
chelan washington
2.8l, 4.0 v6
naw man ur fine if it helps me to i dont mind
