302 swap help
djkommando
Annville, PA
86 ranger
306 HO
i have an 86 ranger 2wd that im going to put a 302 out of an 87 mustang in it. my biggest problem that i found after reading is that the mustang uses a cable clutch for the t5. whats the best way to make the t5 work or is there a better trans option out there. oh and by the way, im plannin to build the motor to somewhere between 300 and 350hp. also any other useful tips to make the swap go easier would appreciated
thanks,
jeremy
Teddyzee
December 2011 STOTM Winner
MTOTM Winner
15
Nova Scotia Canada
5.0L HO, GT40 heads, GT40 intake, 65mm TB, 1.7rr, Tri-Y headers, dual 2.5" exhaust, Flowmaster muffl
The hydraulic clutch is easy.
Search TRS, RPS, and v-8ranger.com, and you'll find lots of very similar options.
djkommando
Annville, PA
86 ranger
306 HO
i found people using an external slave from an 83/84 ranger and making a plate to mount it, but is it possible to use the internal slave i have now? or one from a different vehicle?
Teddyzee
MTOTM Winner
15
Nova Scotia Canada
There are aftermarket internal slaves available.
They are quite expensive (in the $3-400 range) and many who use them question the reliabilty.
baddad457
18
Opelousas La.
The McCleod T/O bearing used to have reliability issues, all that's been resolved. But with a T-5, there's no need to use one when there are cheaper external slave kits available.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Upgrade your axle to explorer 8.8...you'll need it
SVT
djkommando
Annville, PA
86 ranger
306 HO
i know i have to get the axle, but is there anything special i have to do for a driveshaft?
RangerFabWorks
The O.G blackwidow67
716
Lexington, North Carolina
302
you might need to shorten it depending on where you set the engine. and the input yoke will need to be changed. all stuff a good d-shaft shop can handle.
Iron Ranger
Run lil' ricer RUN!!
MTOTM Winner
22
Minnesota
0.040 punched 302
Get the motor/tranny set up and the axle set up and measure the length you need. Then take the specs to a drivetrain shop and they should be able to build you a driveshaft with whatever joints you want.
I ditched the 2-piece for a single, 3 1/2" driveshaft with spicer joints. Cost me only $195 for everything.
As for the slave? My slave cylinder is only $23 and the bracket can be as simple as a piece of angle iron on the bellhousing(depending where the fulcrum point is on the shift fork)
Spdrcer34
Bremerton, WA
5.0L
Why do you guys bother with the T-5. It requires the shifter hole to be opened up, putting the shifter in a very awkward location. And you have to fab up some cable system, OR go the hydraulic route using parts from aftermarket vendors.
You can use the M5OD from a 97+ F-150 w/ 4.2L V-6. It bolts right up. It puts the shifter RIGHT where it is supposed to go. AND it uses 100% OEM parts.
Ryan
Mac
183
C. Wisconsin
2000
199
Ryan
And it's just a truck transmission, not a performance trans like the T-5. People have done the hydraulic route with all stock Ranger parts before. What is the first gear ratio, torque ratings? The M5OD is the only way to go if running a 4x4.
Dave
djkommando
Annville, PA
86 ranger
306 HO
i got another situation i just ran into. i decided im gonna run gt40p heads but what i need to know is do i have to use the explorer intake as well and do i need anything special for valve train or are the parts (minus the valves) the same as the e7te heads i have now. if theres any other problems someone knows about besides headers that i should be aware of please let me know.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
You shouldn't have a problem, all the parts should be interchangeable...
SVT
Iron Ranger
MTOTM Winner
22
Minnesota
0.040 punched 302
Not in the right hands its not.:D This is the most comfortable shifter I have ever used, so natural.
#1 Lone Ranger
here's how i relocated my shifter
its made out of 1/2" aluminum plate then inserted a steel treaded insert for the knob and polished it out..looks like a Hurst and the 2" dogleg puts the stick just right..it took some time to come up with just the right curve and height..anybody that is interested i could make a pattern and email it to ya.
