Introduction
A Front Aussie Locker is a popular upgrade for the Ford Ranger, Bronco II, and Explorer Dana 35 There has been some confusion as to which Aussie part number is the right locker to purchase. This page will hopefully help clarify which locker to order and provide you with tips to help you get it installed.
NOTE: Be sure to read the Aussie manuals and supplements listed at the bottom of this article.
What Is An Aussie Locker
The Aussie Locker is a fully automatic and precision manufactured automatic differential locking device that does not require any manual operation to activate. It does not require any switches, external compressors, electrical cables, air lines, or pneumatic controls. The Aussie Locker relies on a simple and highly innovative mechanical design which makes use of two distinct sets of forces, “ground driven” forces acting on a wheel when cornering (forces the outside of the wheel to turn faster) and the engine driven forces through the drivetrain. The combination of these two sets of opposing forces and the unique Aussie Locker design allow the automatic locking and unlocking of the driving gears when a vehicle turns or requires differential action.
The Aussie Locker is what some people call a ‘Lunchbox Locker’ because it fits inside of your open (non-limited slip) carrier unlike a Detroit, Auburn or ARB locker that replaces the entire carrier.
Which Locker Do I Need
The 1990-1994 Dana 35 TTB used in the Ranger, Bronco II (1990) and Explorer all take the XD-13527 Aussie Locker. According to Aussie Locker, you can confirm this buy checking the BOM number on the back of the right-side axle beam and comparing it to their chart below. The BOM or ‘DANA PN:’ is located in the top left corner of the axle label.
The Dana 35 TTB used in the 1995-1997 Ford Ranger takes the Aussie XD-13530. We know that we’ve had TRS forums members that had to use the XD-13530 in their 1996 and 1997 Ford Ranger, but we haven’t had anyone confirm that the XD-13530 fits the 1995 Ford Ranger.
NOTE: There was a discrepancy in the chart and I corrected it. Aussie listed BOM 610483 as 1995-1997 Ford Explorer but it’s in fact a 1995-1997 Ford Ranger and confirmed through the Dana Parts Catalog.
Ford Ranger / Bronco II / Explorer BOM Numbers XD13527
| BOM Number | Vehicle | Axle | Axle Code |
| 610300 | 1990 Ranger / Bronco | Dana 35 | XD-13527 |
| 610365 | 1990–1992 Ranger / Bronco | Dana 35 | XD-13527 |
| 610366 | 1990–1992 Ranger / Bronco | Dana 35 | XD-13527 |
| 610410 | 1993–1994 Ranger / Bronco | Dana 35 | XD-13527 |
| 610419 | 1993–1994 Ford Ranger | Dana 35 | XD-13527 |
| 610436 | 1992–1993 Ford Ranger | Dana 35 | XD-13527 |
| 610483 | 1995-97 1/2 Ranger w/ABS | Dana 35 | XD-13527 |
| 610437 | 1992–1993 Ford Explorer | Dana 35S | XD-13527 |
Ford Ranger / Explorer BOM Numbers XD13530
| 610556 | 1998 Ford Explorer | Dana 35 | XD-13530 |
| 610581 | 1995–1996 Ford Explorer | Dana 35 | XD-13530 |
| 610582 | 1995–1996 Ford Explorer | Dana 35 | XD-13530 |
| 610585 | 1996 Ford Explorer | Dana 35 | XD-13530 |
| 610586 | 1996 Ford Explorer | Dana 35 | XD-13530 |
| 610642 | 1998 Ford Explorer | Dana 35 | XD-13530 |
| 610643 | 1998 Ford Explorer | Dana 35 | XD-13530 |
| 610644 | 1997 Ford Explorer | Dana 35 | XD-13530 |
| 610645 | 1998 Ford Explorer | Dana 35 | XD-13530 |
| 610652 | 1997 Ford Ranger | Dana 35 | XD-13530 |
| 610774 | 1999 Ford Explorer | Dana 35 | XD-13530 |
Why Isn’t The Locker Listed For 1998-2011 Ford Ranger 4×4
From 1998-2000 the Ford Ranger 4×4 used PVH locking hubs in the front axle. From 201-2011 the Ford Ranger 4×4 used a live front axle that was always spinning. Even in 2WD.
Steering Difficulty: With a live front axle, the locker will try to force both front wheels to turn at the same speed. When turning, the inner and outer wheels need to spin at different speeds. A locked differential prevents this, causing the vehicle to want to push straight ahead. This can lead to erratic and difficult-to-control handling, as well as increased tire wear. On wet or icy pavement, a front traction device can cause the vehicle to “plow” straight ahead during a turn (understeer) because the wheels cannot easily differentiate their speeds.
Component Stress: The added strain from the wheels being forced to turn at the same speed during a turn can put immense stress on components like the tie rods, half-shafts (CV axles), and even the differential housing, potentially leading to premature failure.
If you do want a locker in the front of your 2001-2011 Ford Ranger 4×4 and plan to drive it on the street, I would recommend that you: Convert Ford Ranger Live Axles To Manual Hubs
Confirming Fitment
You can verify which Aussie locker will fit your Dana 35 by measuring the spider gear.
- 1.557″ OD = XD-13530 Locker
- 1.617″ OD = XD-13527 Locker
Below you can see where this spider gear (side gear) measured 1.622″ meaning that it needs the XD-13527 Aussie locker.
Locker Not Fitting The Carrier
Due to the overall bigger size of the Aussie Locker compared to others and due to Casting differences of the Dana 35 differential cases, it may be necessary to grind/clearance your carrier during install. Also due to the size of the locker you will not be able to rotate the Cam gears of the locker inside of the case during the installation. For more information see: UPDATE – Dana 35 Clearancing The Carrier.pdf
NOTE: Be sure to read the PDF document. It will reference these photos, but don’t perform the work without reading the document.
Locker not fitting into carrier; will need to be clearanced.
Checking the cross-shaft (pinion shaft) to spacer clearance (.005 – .020)
Sliding the 2nd cam gear in after clearancing the carrier.
Measuring the center gap (.140 – .170).
Aussie Manuals
2022 Aussie Locker Standard Install Manual.pdf
XD-13527 Supplement Dana 35 Ford TTB.pdf
XD-13530 Supplement Dana 35.pdf
XD-13530 XD-13527 Supplement Dana 35.pdf
XD-13527 Dana 35 Model Installation Manual
Aussie Locker Website
Aussie Automatic Locker – Torq-Masters
Price An Aussie Locker
Related Discussion / Articles
Which Aussie locker? 1997 TTB (UPDATE)
Installing A Lock-Right Front Locker
Lock Right Locker Installation #1
Picking A Differential For Your Ford Ranger
Locker Comparisons – Understanding Differentials/Lockers
Gears and Lockers Installation
Ford Ranger 4×4 Front Axles 1983-1997
Convert 2001-2011 Ford Ranger Live Axles To Manual Hubs
1983-2011 Ford Ranger Off-Road Builders Guide
About The Author
