Fuses protect your vehicle’s electrical system from overloading. If electrical parts in your vehicle are not working, the system may have been overloaded and blown a fuse. Before you replace or repair any electrical parts, check the appropriate fuses.
The following charts tell you which fuses protect each electrical part of your vehicle. If a fuse blows, all the parts of your vehicle that use that circuit will not work.
Once you have determined which fuses to check, follow the procedures under Checking and Replacing Fuses further down this page.
Passenger Compartment Fuse Panel
passenger compartment fuse panel location
passenger fuse panel
No. AMPS Circuits protected
1 7.5 Power Mirror Switch
2 7.5 Blower Motor Relay, PAD Module, Air Bag Diagnostic Monitor
3 7.5 Left Stop/Turn Trailer Tow Connector
4 10 Left Headlamp
5 10 1998-1999: Data Link Connector (DLC)
6 15 2000: Overdrive, Back-up Lamps, DRL, 4×4
7 7.5 Right Stop/Turn Trailer Tow Connector
8 10 Right Headlamp, Fog Lamp Relay
9 7.5 Brake Pedal Position Switch
10 7.5 Speed Control Servo/Amplifier Assembly, Generic Electronic Module (GEM), Shift Lock Actuator, Blend Door Actuator, A/C-Heater Assembly, Turn Signals
11 7.5 Instrument Cluster, Daytime Running Lights (DRL), RABS Resistor
12 Not Used
13 20 Brake Pedal Position Switch
14 20 Rear Anti-Lock Brake System (RABS) Module
10 4 Wheel Anti-Lock Brake System (4WABS) Module, 4WABS Main Relay
15 7.5 Air Bag Indicator Lamp, Alternator Indicator Lamp, Instrument Cluster
16 30 Windshield Wiper Motor, Wiper Hi-Lo Relay, Wiper Run/Park Relay
17 25 Cigar Lighter, Data Link Connector (DLC; 2000)
18 15 Driver’s Unlock Relay, All-Unlock Relay, All-Lock Relay
19 25 PCM Power Diode, Ignition, PATS
20 7.5 RAP Module, Generic Electronic Module (GEM), Radio
21 15 Flasher (Hazard)
22 20 Auxiliary Power Socket
23 Not Used
24 7.5 Clutch Pedal Position (CPP) switch, Starter Interrupt Relay, Anti-Theft
25 7.5 1998-1999: Generic Electronic Module (GEM), Instrument Cluster
26 10 Battery Saver Relay, Electronic Shift Relay, Interior Lamp Relay, Power Window Relay, Electronic Shift Control Module, Dome/Map Lamp, GEM, Instrument Cluster (2000)
27 15 1998-1999: Electric Shift, Backup Lamps, Daytime Running Lamps (DRL), Transmission Control Switch, Pulse Vacuum Hub Lock
28 7.5 Generic Electronic Module (GEM), Radio
29 15 Radio
30 10 1999-2000: RABS Test Connector
15 1998: Park Lamp/Trailer Tow Relay
31 Not Used
32 Not Used
33 15 Headlamps, Daytime Running Lamps (DRL) Module, Instrument Cluster
34 Not Used
35 15 1999: Park Lamp/Trailer Tow Relay
10 1998: RABS Test Connector
36 Not Used
Power Distribution Box
power distribution box
The power distribution box is located in the engine compartment on the driver’s side near the fender.
1 50 I/P Fuse Panel
2 40 Blower Motor Relay
3 50 4 Wheel Anti-Lock Brake System (4WABS) Module
4 20 Power Windows
5 50 Ignition Switch, Starter Relay
1 10 A/C Relay
2 20 Auxiliary Power Point
3 20 Electronic Shift Relay and Electronic Shift Control Module
4 20 2000: Fog Lamp and Daytime Running Lamps
15 1998-1999: Fog Lamp and Daytime Running Lamps
5 15 2000: Trailer Tow Park Lamps
10 1998: Air Bag Diagnostic Monitor
6 10 Powertrain Control Module
7 30 4 Wheel Anti-lock Brake System (4WABS) Module
8 30 PCM Relay
9 20 Fuel Pump Relay and RAP Module
10 15 Horn Relay
11 15 Parklamps Relay and Main Light Switch
12 30 Mam Light Switch and Multifunction Switch
13 15 Heated Oxygen Sensor, EGR Vacuum Regulator, EVR Solenoid, Camshaft Position Sensor (CMP), Canister Vent Solenoid
14 30 Alternator Voltage Regulator
15 Not Used
1 Wiper Park Relay
2 A/C Relay
3 Wiper Hi/Lo Relay
4 PCM Power Relay
5 Fuel Pump Relay
6 Starter Relay
7 Horn Relay
8 1999-2000: Fog Lamp Control Relay
1998: Washer Pump Relay
9 Blower Motor Relay
10 1999-2000: Foglamp Isolation Relay
1998: Foglamp Relay
11 Not Used
12 Not Used
13 Park Lamp/Trailer Tow Relay
14 Washer Pump Relay
1 RABS Resistor
1 RABS Diode
2 Electronic Engine Controls Diode
If you need to check a fuse, follow these steps:
1. Find the fuse panel, which is located in the left end of the instrument panel. The power distribution box (described earlier in this section) is found in the engine compartment, mounted on a bracket attached to the driver’s side fender apron.
To access the fuse panel, remove the fuse panel cover by inserting your finger in the divot and pulling on the cover. The underside of the cover contains four spare fuses. A fuse pulling tool is located in the lower right corner of the fuse panel in case you need to replace a blown fuse.
Color Coded: The spare fuses for your vehicle are color coded as follows:
  • 10 amp — red
  • 15 amp — light blue
  • 20 amp — natural
  • 30 amp — light green.
See further down on this page for examples
2. On the fuse panel cover, find the number of the fuse you want to check. The diagram on the cover tells you where to
locate the fuse on the panel.
3. Check the fuse to see if it is blown. Look through the clear side of the fuse to see if the metal wire inside is separated. If it is, the fuse is blown and should be replaced.
blown fuse example
Another method for testing fuses is to use a Bussmann fuse tester. There’s no need to remove the fuse from the holder. You simply adjust the prong width on the tester to line up with the bare metal spots on the end of the fuse and then watch for the indicator light to glow signaling that the fuse is good.
bussmann fuse tester
how to test a fuse
4. Replace the fuse with one that has the right amperage rating
*WARNING Always replace a fuse with one that has the specified amperage rating. Using a fuse with a higher amperage rating can cause severe wire damage and could start a fire.
5. Put the fuse panel cover back on.
Even after you replace a fuse, it will continue to blow if you do not find what caused the overload. If the fuse continues to blow, have your electrical system checked.
Fuse Color / Ratings:
As mentioned above, fuses are color coded to their AMP rating. See the image below for examples.
fuse sizes
Related Articles:
Ford Ranger Owners Manuals
About The Author
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
