aeidian
- Oct 7, 2010
89 2.9 4x4
I had a noticeable bearing issue several months ago on the front axle. I replace both sides inner and outer and made it about a week before it sounded exactly the same as it did before I put the brand new bearings on there. I pulled it all apart again and one side the bearing was obviously trashed, looked like the rollers had been run through a meat grinder. When I first inspected them before I replaced them the outer lock nut was just a couple threads from the outside, I could freely spin it with my hand, so it wasn't tightened down. My mistake was not using the proper axlenut socket (I used a flat head screwdeiver and a hammer to tighten it down) and have no idea if I even torqued it to specs but it was tight. I probably didn't pack it as good as I should have because used the old handful of grease and repeatedly push it against the palm of my hand to mash the grease in. As I said it didn't make it a week before that bearing got ate. The axle shaft is fine. I again put new bearings on but this time bought the actual axlenut socket and torqued it properly. I even put a drop of locktight on the outer axle nut hoping it would help (someone is invariably gonna call me a dumbass because they'll say it got in the bearings, but I didn't see any evidence of that) but it made it about a couple weeks before it again started womp womp womping. This time I bought a bearing packer, the kind you put in the dish and push down on and it forces the grease through so I know it was packed. Its been about a month and now AGAIN ITS MAKING NOISE. Everytime I put this thing together I can't help but think the person that designed this was stupid, it has a seal on the back to keep the grease in but there's nothing on the front. The bearings aren't bone dry but its obviously lost alot of grease I put in there. I'm about to pull my hair out over this.
Sent from my SCH-I405 using Tapatalk 2
