- Oct 14, 2010
- Williamsport, Pa
- Automatic
I'll have to do that. So I'm guessing that it's not the springs themselves that push the axle it's wherever they are mounted? Iirc there was someone on here that used yota springs and it moved the axles a little bit.
Let me put it in lamens terms for you. Leaf springs have center bolts that position the axle. If you want the axle forward an inch, mount the hanger forward an inch. Or reverse that if you want it back an inch.
Same goes for link suspensions. The length of the radius arms, position of the coil buckets, and position of your steering box locate the axle.
