Noob’s 88 ate up the trails today.
96 long bed 4x4 with manual trans, transfer case, and a 2.3 that runs good.
That's an unusual combo for a 96 isn't it? I thought it was pretty difficult to get a 4 cylinder 4x4 by then.
From the 96 sales brochure
Looks like the last year for that option, 97 brochure doesn't show it.
Saved one from the scrapper, it'll end up being parts, as it's too rotten for the road and doesn't have paperwork. It's a 96 long bed 4x4 with manual trans, transfer case, and a 2.3 that runs good.
It's from the middle of Vermont and lived in Stowe for part of it's life. Has a cobbled together "cold air" intake, some led lights, some aftermarket stereo stuff, and a healthy dose of spray paint on the grill.
Sweet, the unicorn of a transmission, 4.10 D35 and 7.5 and a manual 1354...
Still has the big joints, just don't put it in front of a doubler doing rock crawling with 33's :)
Fair point, I may save the diff i may not, it is low mileage with 4.10s, I'm more after the beams and brakes than anything. Doubler is in the future, most of the reason I snagged the truck was for the manual transfer case.
It's a weird truck, it's the most base truck I've seen in a 4x4 but has 4 wheel abs, tach cluster, and factory fog lights. Vinyl bench seat, rubber floor, solid rear window though.
Sounds good though. I would love it
Center console got pulled in my green Ranger this afternoon. For those who don’t know, I built a custom center console years ago and haven’t pulled it to finish it. Well, that’s about to change. It’s going to get finished before it goes back in. Hopefully I can scratch up some extra money to get the brake controller, CB and GMRS radios, and whatever else I think I want.
Also made a deal, I’ll be ordering upper control arms later this month. This week is going to be dedicated to thrashing on my project.
Off to a dubious start… yesterday proved to be minimal progress on the Ranger because every 5 minute project I tried to knock out took at least an hour because of unexpected problems. One of which was reaching into my bin where I have 1/4-20 riv-nuts and the first two I pulled out wouldn’t screw onto the mandrel. Turns out my 100 pack of them contains 32 M6 and 68 1/4-20. That was a good few minutes of my life checking them all that I shouldn’t have had to do.
Also managed to fall and twist/roll my ankle, tweak my wrist, and make my bad hip mad. Joy.
Some simple maintenance this Tuesday. Need this back before the roads are salted.
Ya gotta pull the engine to change the oil?
I have made a ton of posts in the past complaining about how I can't find clutch hydraulics worth a damn. It turns out the pressure plate I found in the trunk of a car I bought on FBMP was the problem and the Bronco couldn't hold up to the force. I exploded about 3 slave cylinders, a master, some spot welds in the firewall, and the crankshaft thrust bearings.
What did you do to your Ranger today? (Part Deux!) What did you do to your Ranger today? (Part Deux!)
Installed wheel spacers so the Ground Hawgs don't rub.
