- Jun 15, 2011
- Chicago, IL
- Automatic
Hi all...
Weird problem.
1998 Ranger Sport
6-cyl, 3.0
2WD, Auto
150K miles approx.
Ok, prior to today, truck has run fine, battery seemed healthy at 2 years old, starter has always kicked through with vigor, and my gauges have given me no indication there is anything wrong with the charging system (voltages are good). The only thing out of the oridinary lately is I replaced all my front end ball joints and tie rod ends, but I can't imagine that would have anything to do with what I'm about to describe, but there it is nevertheless for thoroughness. Anyway, today I went out to start my truck, and I was met with the classic "rapid fire clicking" won't start situation (from the inside of the cab, the rapid fire sound comes from somewhere near the passenger side firewall). Not suspecting the starter/solenoid, I put a rapid charger on it for a couple of hours, but that didn't fix the situation (and it's worth noting the charger hadn't done an auto shut off which indicates the battery wasn't yet fully charged...odd). Decided to jump it, and it did start immediately after I hooked up the jumper cables, but the starter was sluggish (still could be the battery the a bit low). As it is currently, it will NOT start unless I jump start it Here's where it's interesting, and I'm sure I'm looking at some factory codes or something:
When I turn the key to start it, whether or not I actually do start it, the dash lights, and exterior driving lights all flash 4 times in relatively quick succession (about 1 per second), then quit. Each time they flash there is a corresponding "relay-like" clicking coming from the driver side dash. Immediately following that, and for as long as the key is in the ignition, they stay on for about 4 seconds, turn off for one, then repeat over and over, 4 seconds on, 1 second off. This is true if the truck is running or not; however, if I have my headlights on, they and the driving lights remain on, but I still hear the "relay" clicking at the usual 4/1 intervals. The interior overhead lamp, if on, is excluded from all this. If the truck is running, I cannot shut it off using the key, but the engine quits the instant I push on the brake. If I attempt to start the truck without jumping it, it won't start (same "rapid fire" clicking), even if I run the truck for half an hour or so (and I forgot to check to see if the gauge indicated it was charging).
Any clues? I think the 4 quick flashes just before or while starting it, and the 4 second s-l-o-w flash seems to me to be a factory code, so if anybody knows what that code means, I'd be greatly appreciative.
Thanks.
Thought: After a little Googling, I'm wondering if any/all of the symptoms could be related to a short, or a vacuum leak? The brake turns the engine off like I hit a switch, and as it's been described online, a vacuum leak would starve the engine of enough vacuum if the brake is depressed. But I'm still left wondering why I can't start the truck without jumping it unless I just happend to ALSO have a prematurely bad battery which decided to fail at the exact same time another problem appeared. Thinking out loud...
Weird problem.
1998 Ranger Sport
6-cyl, 3.0
2WD, Auto
150K miles approx.
Thanks.
