Hey guys. Has anyone done this in a 98+ Ranger? What kind of placement issues do I need to worry about? Its also 4wd and id like to keep it that way. Any advice on a good transfer case along with this trans?
I'm not a big 4x4 offroad type person. All the HD truck transmissions and transfer cases available . . I wouldn't be the person to ask. I know here my expertise is and isn't A 347, I do know about. Where that is going to be torquey for a SB, it should not be a problem for the HD transmissions that came in the fullsize trucks. Not a problem at all. But someone else will have to steer you to the best choice.
For fitment, consider measuring the existing engine trans from the motor mounting position and compare to this TKO600 and add on for the T/C, then compare for trans mount and driveshaft length.
On replacement Trans and T/C, what the budget look like ? (don’t need an answer)
If short on cash start looking for swap info and determine the best fit but if funding is available then consider after market used or new, a lot of good stuff out there and adaptable to most anything.
For
