The computer has no fuel pressure sensor.
Nor do most fuel injected engines.
Standard computer programing will turn on the fuel pump for a few seconds when key is turned on, then shut it off until engine RPM is above 700, so off until engine starts.
Fuel Pressure Regulator(FPR) is a valve with a spring to hold it closed, it is connected to the fuel rail and the fuel return line that goes to the gas tank.
It also has a vacuum line connected to the intake manifold, when engine is idling(highest vacuum, lowest fuel use), the vacuum pulls the FPR valve open so un-needed fuel goes back to the gas tank.
There is a diaphragm in the FPR that holds the vacuum, if it had a leak then raw fuel would be sucked into the vacuum line and then the engine.
Check the vacuum line on the FPR for fuel.
You can drain the fuel pressure via the schrader valve, then turn key on, count to 5, turn key off, repeat 3 times, then test schrader valve for pressure, if you have pressure again then pump is working, and FPR is not stuck open, but FPR could still be leaking.
