85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
- 5.0L
Easiest way is to turn the oil pump shaft with a drill. Keeps the rest of the stuff from getting dry started.
It should still have some oil in the bearings, I cranked mine with the dizzy unplugged until I had oil pressure before I tried to fire it and I haven't notice any large parts flying out of it yet.
Me too. Good thing is, they are in the front of the engine. I put mine in a tooth off and couldn't get it timed quite right. Took about fifteen minutes to fix that problem.
Mine is a tooth or two off with the plug wires rotated one post around from where they should be. The Explorer FEAD wasn't intended to be ran with a vacuum advance dizzy.
Should i run a fuel pressure regulator? If so would this one be sufficient?
http://www.summitracing.com/parts/sum-g3032b/overview/
I have no regulator and it doesn't seem to care.
Don't think i am getting spark and i can't figure out why. I haven't changed any of the wiring from when i was running my 2.8.
Initially mine plugged into where my 2.8 unplugged from and ran great. I had the dizzy out for my cam/head swap a year later and the connector crapped out on me. I had power where the pigtail plugged in but I couldn't get anything to the dizzy connector.
This wouldn't be why you couldn't get the 2.8 to run is it?
