- Aug 11, 2007
- Age
- 69
- Ontario, Canada
- Automatic
- My credo
- Love Thy Neighbor
I would do it with a volt meter...you can get a cheap one, but they don't have an accurate scale for measuring...I got one for about $5 that was made in China...it does the basics, but that's about it...and the crappy leads fell apart on me at one point...and it doesn't have very good increments...meaning it jumps from 10 VDC right up to 1,000...and the scale is so small you really have to bust your eyeballs to read it...
Best to invest in a good digital one if you're going to spring for it...or take the coil to a shop to have them test it...and the coil wire to the dizzy...if it doesn't have the right resistance then the current won't be the same at the dizzy...
There were a few other vids on testing other components in that series...I ended up watching a bunch of them before I found the ones that I needed and learned to test the components...but mine turned out to be a carb problem...too much gas can really dampen the ignition system in cold weather...
