- Jun 2, 2010
- Automatic
Test the distributor...if you have a voltmeter that measures in 1000 volts DC put it on that setting or you may damage it...if you're not getting around 9000 volts out of the coil it may be bad...and replacing that will get you running...
Oh, wait...are you running coil packs with 8 plugs or is it 4 plugs with a coil on the fender?
i got one coil on the driver side fender and 4 spark plugs on the passenger side of the truck what kind of set up is that i know its stock be whats it called.and i dont have a volt meter but its getting a good steady blue spark at the coil and to the distributor i tested the old fashion way by holding it to metal but wouldnt it be good if it is blue?And also i put new wires on today and still no blue spark at the plugs ony yellow
