Transmission interchange question
Raptor700
ASE Certified Tech
Nanaimo
BC - CAN
Vehicle
Drive
Hey everyone
I have a 2003 ranger FX4 Level 2 , my daughters first truck she purchased last wk. was a rare find over here on Vancouver island. Other than the box rusted out and rear leaf spring hangers rusted off , not a bad truck. Fixed the wiring for the left turn signal, replaced the T-case actuator motor and cleaned er up! My question is, what year of the 5r55e will interchange with my kids 2003 auto trans ? Is it only the 01-03 4.0L’s with the 5r55e ,or can I interchange with a later yr ranger say an 2008 4.0L with the 5r55e?
I can’t find much on the web but someone was saying only 01-03 you can swap out trans and the later yrs you would have to modify the electrical connectors. Not sure on this topic?!?!?!
Good place to figure this out is www.car-part.com. Good place to look for a used transmission also. It will list the exact drop in years, just make sure you search "all areas" to get a good interchange.
I do not know all the ins and outs of the different models, but I see right away using that site, that the rangers that year with a 4.0 could have had a 5R44E or a 5R55E. I am going to assume you are sure you have a 5R55E. When I looked up a 2003 4x4 with a 4.0 and a 5R55E, 2001 thru 2005 transmissions popped up. Compared to other types and years, that is a pretty wide range.
Thx for the reply
After some digging around I found the 2001-2011 5r55e trans will fit, as long as it’s the 4.0L and not the 3.0L as the bell housings were different bolt patterns for those engines,and the 16pin connector will match up for plug n play.
