Wireless keypad question
BobSacamano
Forum Member
Brookhaven
MS - USA
Vehicle
Drive
I have a 1996 Ranger that I added a RAP module for keyless entry and antitheft. I am considering adding a keypad from an Explorer, Crown Vic, etc. but I am timid on cutting a hole in the door. Will a Ford wireless keypad work on this module?
Wire it all up and test it before physical installation. Just lay the parts on the floor all wired up to make sure it all works electrically.
I’m talking about a wireless keypad that are on newer Fords. I’m curious to know if it will communicate with the rap module?
If its wireless...
One would think you'd have to program the module to recognize the output from the wireless key pad. Similar to programming fobs...
Though I don't know for sure... I think you might be trying to blend old tech with new tech it may not understand.
I honestly don’t know. Is the RAP you added a Ford product? You didn’t really include enough information for anyone to say “yes” or “no”. The best answer really is “try it and find out.” And you should be able to wire everything up and try it without cutting or drilling holes in anything important.
Yes the RAP came out of a 1996 Ranger. I wired it up using the factory diagrams. I put it in programming mode and synced it to Fobs I got on EBay. It works perfectly. It would be really simple to wire up a keypad from another Ford vehicle but I don’t trust myself to cut the hole. My 2021 bronco has a stick on wireless keypad that you can put anywhere you want so I thought maybe it could be used on the Ranger.
I strongly suspect that the 2021 keypad is most likely using a different radio communication protocol than the 1996 RAP system and won’t be able to link up. If you try it and it works, let us know so the information can be added to the tech library somehow. That’s how we grow the knowledge base.
