Swapping 1990 Bronco 2 automatic transmission to one out of 1992 explorer 4x4
Ozzy468
Nashville
Good afternoon all. My friend took out his factory 1990 bronco 2 transmission in favor for one out of a 1992 explorer. This goes from 1 to 2 solenoid controlled sifting. Do I need to swap valve bodies??? Wiring ideas are much appreciated. Thank you!!!
Looks like you need a different computer setup and harness or you won't have a 3-4 shift. This is from the AL4D transmission article in the tech section.
Best I can tell from ATSG manual, the changeover date for single to dual solenoid versions occurred in mid '88 The single solenoid originally on the trans 85-87 controls only the TC lockup function. Later models had the 3-4 shift inhibit solenoid added in 88. And I have both a 90 2.9 A4LD and a 93 Explorer A4LD here, both have the dual solenoid setup.
In the link below, the guy replying alludes to the fact you may be able to change out the valve body.
Thank you
Thank you to all who helped!
