- Sep 10, 2023
- Sacramento, Ca
- State - Country
- CA - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 4.0L
- Manual
- Total Drop
- 3/5 level
- Tire Size
- F: 235/45R17 R: 275/40R17 (1999 SVT Mustang17x10)
- My credo
- Send it Hard and Fix it Harder
I was driving about a week ago and I noticed I was going 0 MPH and my voltage was negative, oil pressure was through the roof, and my coolant and feul gauges stopped working. Beforehand my tachometer was out. My grandfather said it never worked for him. He got it straight from the factory/ lot. I got my tachometer to work for roughly 30 seconds by turning on my engine with my lights on and smaking my dash 3 times. It looks like it lags almost. So my speedometer/odometer, tachometer, oil pressure gauge, voltage gauge, fuel gauge, and coolant temp. They all went out including my check engine light and parking brake light. I was trying to fix my tachometer and then this happened. My dumbass forgot to disconnect the battery and it started sparking and I stopped after it sparked. I'm looking at it right now completely pulled out and the mother board looks teared at the bottom plug spot.
I checked some fuses I thought that would be connected to the instrument cluster. Any help would be awesome. If I cant fix this instrument cluster I found a digital dash for 60 bucks that plugs into obd2 port. I'm not sure it will work but i can return if it doesn't work. If it doesn't I found some individual gauges I'd rather install than a new cluster itself. I'd rather do that since I dont want to gamble 200-260 dollars and it not work and not be able to return it.
