lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
- Aug 6, 2007
- Butler
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Automatic
- Total Drop
- 4”
Ehh, if you can weld and fabricate, a turbo isn’t stupid expensive, and you would just dump it right down the throat of your stock intake assuming it’s aluminum and not plastic.Turbo is out of the question as they are stupid expensive and I’m pretty sure I would need a separate intake to go with it.
This shift kit you speak of how does it work? My knowledge of automatic transmissions is limited all I know is there is more to go wrong. I thought a “shift kit” was just for replacing the solenoid springs and some clutches springs… . Not sure how that would affect your ability to spin the tires, unless it changes the shift pints or the gear ratios. Besides that you are talking about the 4.0. Of course it’s got power.
Shift kits go in the valve body mostly. At least with the TransGo kits. Drop the pan, filter, and remove the valve body. Changes springs and valves in the valve body, plus you usually drill out a couple holes in the valve body and separator plate. Firms up the shifts and remedies issues with the stock design. I didn’t expect a whole lot out of it when I did it to the A4LD, but it was night and day. My manual transmission 3.0 would have spanked that 92 4.0 auto before the shift kit. After? Not so much…
I have some video I’ve been fighting with trying to get in a useable format from when I did the shift kit in the 92. One of these days I’ll get it handled. I’m getting ready to do a Stage 2 shift kit combined with a Jmod in my green Ranger, but that is a 4R70w trans. I will get video of that. My buddy Paul is talking about doing a shift kit in his 98 Ranger and I intend to get video of that, which will use the same shift kit you would.
