V8 swapping 83 ford ranger
ranger83jo
Colorado
CO - USA
Vehicle
Drive
2WD
2.3 (4 Cylinder)
195/75/R14
I have a 1983 ford Ranger I've owned it for about 15 years and am trying to gather information and make a part list as I plan on putting a 302 in it and cannot find any information on what transmission will bolt up to it ideally I would want an aod but am at a loss as to weither it's a c4 or c6 any information would be greatly appreciated
An AOD is an AOD. It was a stock transmission found behind the 302/5.0L in cars and trucks.
C4 and C6 were older non-OD transmissions.
AOD was like the C4 and C6 in this is was full mechanical/hydraulic control and used a TV linkage from the carburetor (or throttlebody?) to control shifting. AODE was a later version of the AOD with electronic controls for shifting. The 4R70W was an even later revision of the AODE with more refined computer controls.
Which one you use will be best determined by what you are planning to use for fuel control on your 302 (carburetor or EFI) and if you want to consider adding a standalone transmission controller for one of the later transmissions.
I believe a C3/ C4 should both work without a body lift, anything bigger and you are gonna have to lift or smash the tunnel up a bit to make room...
in the tech library there are several documented swaps (mostly newer "5.0", not an oldschool "302"), but there is at least a couple 302 swaps.
about 2/3 way down, left colum, "V8 swaps"
Howdy! Welcome.
If I were more tech savvy, I’d give ya the links that are here on this site.
Like what has been mentioned, look in the Tech Library, then under the older rangers. Lots of info.
Check under the engine section under V-8 swaps, several articles in there that will walk ya through it.
C4's and C6's have vacuum modulators, AOD's do not, they rely on governor speed like the other 2 with the throttle position being the main shift control. A C6 eats up more power, is bigger, and would be overkill unles your engine makes a ton of power. I used a C4 and 3.00 gears behind the mild 351 in my Ranger because I had one and because I like the way a C4 shifts better. If you're planning to run EFI and a PCM, an AODE might be a better choice for you.
I've got a ZFS5-42 in mine
Personal experience... it sucks to go back in and reswap the trans because you decide you want OD...
Ok, but that's a manual transmissions. The op was asking about automatics. Unless that was a size reference in regards to the C6 being big?
I don't have the experience, but I agree. If you want OD, get OD. Better to do it now than wish you had and change it later.
is it going to be a cruiser? hot rod? track? 2wd? 4wd?
why the 302? why not a 351? or 460? is it a perception of its the easiest choice?
it can definitely be pretty easy to do. especially with a c4.
your current trans if stock is either a c3 or c5. the c5 can be outfitted to work with a v8 bell. the c3....meh.
i currently have a 302,c4 advanced adaptor conversion,1350 tranfer case set up in a 1984 ranger. tranny overhauled and beefed up for big power. probably has 3500 miles on it. no hard miles just traveling/work. motor out of 1979 tbird with about 60,000 miles does not burn oil. willing to sell as one if interested. going to put a roller rocker 302 in built to a 306,gt40 heads,cobra efi gt40 intake,cam ,headers,and 4r70w with np205 transfer case. not anything wrong with what i have for sale just updating. also put in explorer front/rear ends. interested i live in north central idaho. 208-874-7848 marvin
if you get a AOD, while it is out and freely movable, take it to a transmission shop and ask them to check the 4th gear band to make sure it isn't burnt out. (ask me how I know this) will save you head aches in the long run, as this is a common problem with theses transmissions.
(update) i got a 1986 Lincoln mark 7 with a 5.0l ho efi with a aod transmission i just need some guidance on transmission mount and if the motor and transmission length are the same as a 2.3l 4 cylinder inline and a c3 transmission of what i would need to do to get a correct length driveshaft for it
The Mark VII transmission is unique compared to all other aod - the tailshaft housing is longer.
is there a driveshaft from another vehicle i could get that would fit or do i need to get a custom one made if that is the case i have no idea where i would go to get it
measure it
