stuck intake manifold
Featured Build Threads
washington
i cant get the upper intake manifold off, ive unbolted all 6 bolts and everything and its still stuck solid, 4.0 v6 ohv please help
  • Like
Reactions: gaz
Might need to take a rubber mallet and pop the top of the intake (side to side) a few times. If youre sure you got all the bolts its probably the gasket glueing it down
@rangerrobee ,
Is your 94 an EGR engine? If so, you will need to also disconnect the EGR valve from the upper intake manifold.
hit it with a hammer
gaz is right. But (rubber) hammer it, if you're sure there is nothing else holding it on.
Event Coverage
Featured Ranger Based Vehicle
