corerftech
Ill preface this, I know what SPOUT is and have already corrected a shorted SPOUT condition with a new Standard Brand DIS, a replacement coil (exhaust) and a wide variety of damaged wires by former owner BUBBA from Mississippi. But alas it has returned unexpectedly after I tampered with most of the front end.
I have had the entire engine bay apart, have corrected probably 20 damaged wires, a MAF issue..... all prior to Sunday reassembly.
I have had to do so much to trans/clutch/instrument panel/coils/plugs/cooling..... it was a horror show.
Tonight I finished assembly enough to test drive. 93 octane in it, fired it up and test ran in garage.
It threw a code 18 which hasnt been around for 3 weeks, since new DIS installed and all wiring corrected. That is the only code now and it wasnt there a week or so ago when I was posting about MAF faults.
Unlike prior test runs, it ran really well with MAF resolved and the engine back to bone stock form, stock intake system, OEM MAF, etc.
This is a 1990. I have had to reinsulate all wiring on black and grey DIS connectors due to faults (which corrected the code 18 prior).
I am an electronics tech, its really good work. There should not be a fault in SPOUT (there was a short right at shield entering connector).
I never traced the SPOUT from end to end and physically verified every inch in the bundle.
Ill add this, my tach was DEAD at start of repairs, replaced the DIS and tach began to work.
Tach now bouncing at times (like its stumbling when its not), but tach still works. That has been the case since the tach started working, has always exhibited a funky bounce at times.
Now I disturbed the entire main bundle from ECU to breakout branches due to removing and replacing the inner fender liners (in reversing bubbas hot rod format intake). Reassembly took a bit of work and I didint think I abused the big bundle.....
I have the EVTM in front of me and SPOUT is pin 5 on DIS module (correct me if I am wrong). EVTM shows Yellow/Lt Green (SPOUT) as PIN36 on ECU.
As far as I can see, the SPOUT line is direct from ECU to DIS with the test shorting plug in the middle.
IDM wire, PIN 12 on DIS drives the TACH.
As I understand, ECU sends new SAW to DIS over SPOUT, ECU gets confirmation feedback of the update by the IDM wire, which drives the tach as well.
That is the loop. SPOUT from ECU to DIS, IDM from DIS to ECU. Correct???
Is it possible the IDM wire has a fault that is causing both TACH BEHAVIOR and the CODE 18?
Or is the CODE 18 exclusive/absolute to a fault in SPOUT line from DIS through shorting plug to PIN 36 on ECU??
Also IS PIN 4, Dark Green/Yellow on ECU the IDM line?
It appears in EVTM if PIN 4 is the IDM, then PIN 4 is both DG/Y and BK/Y and has branches the feed the cluster and the tach svc connector.
So bottom line, can IDM faults case a CODE 18 or is it exclusive to SPOUT LINE and its end point devices (ECU/DIS)?
Thanks in advance for the help. My last issue. I could get the truck to stumble a bit but really had to seek it. Low end power (creeping in second gear lugging) was excellent. No stall, smooth, etc. First gear is similar. But every time I start, it backfires when it hits for the first spark (POP). It wasnt doing that prior to final assembly and surgery after the MAF correction. POP started with the revisit of CODE 18.
