SenorNoob's '88 Ext Cab "Build"
Featured Build Threads
Is there any stock or aftermarket pinion brakes available that you know of?
Not that I’m aware of. Quite likely would have to be a custom setup, but I don’t think it would be particularly difficult to make happen.
Yeah, I was thinking of how to go about it years ago. I've thought of adapting brake system from small motorcycle, atv, go-cart, bicycle. Never have gone and actually looked to see if any of those are viable. I have a pair of rotors and calipers meant for a trailer, but will adapt onto 8.8 rear axle, that don't have an option for parking brakes. Once i get to installing them I'll investigate more closely.
I've been wondering what it would take to use the 94-04 Mustang style calipers with parking brake. From memory rotor thickness seems about right. It'd be wild if they just bolted on to the Explorer backing plate. No way Ford would make it that easy.
I picked up a cheap rear view mirror phone mount for my dash cam plan last night. I think the ball is gonna need to be modified to held the weight I want, but gotta get it in the truck to see.
Truck is completely reassembled now. Drives pretty good. The brakes aren't as touchy as they were. Almost think I need to bleed them better, but they're working consistently, and the touchiness may have been because the passenger rear caliper was dragging slightly all the time. (I mean slightly. It took 2 years to wear though one pad.)
This is the phone mount for my dash cam phone.
That wouldn't do at all. The day/night switch was inaccessible. It moved the mirror easily. The phone was floppy, AND it blocked the entire middle 1/3 of the windshield.
This is what it looks like now.
I'm thinking 4 3/4 to inch magnets on the bottom and something to tighten that ball better (Maybe even just set it where I want and epoxy it in place.) then wrap the bottom with bandage tape so it doesn't scratch the dash up and it'll be ready. If that doesn't work out, I have a plan to replace the whole arm and ball with a single plate.
Completed mods to the dash cam mount. 2 pack of 99¢ bar magnets from harbor fright and some of their super glue. Hose clamp works great on the ball mount.
Video Test:
Since the fuel pump swap, I've had hard starts at 1/4 tank or less. I noticed week before last when filled up that there was an awful lot of air movement when I cracked the gas cap. So this time around when it got 1/4 tank, I pulled the cap and let the pressure equalize. No more hard start. All the way down to empty.
Apparently it's been pulling a vacuum on the tank? LOL. IDK how when the line to the charcoal canister is unhooked. (It does have a spot where the in-frame pump was mashed flat though so maybe air tight there?) That'd be about right with my luck. This whole time it was just the pump not getting much fuel cause the tank was under vacuum.
On a more positive note, Filled up this morning and calculated out to 19.1MPG
Featured Ranger Based Vehicle
