- Aug 14, 2007
- UT
- 4.0L
- Total Lift
- 5
- Tire Size
- 33
Regarding your intermittent issues - have you checked the wiring connection at the crank sensor? It makes a good 90 degree curve or so coming from the plug. Many years ago I had a 4.0 that would stumble every now and then and it was because the crank signal was getting interrupted ever so slightly by some slightly broken wires and a corroded/greasy connector/terminals on the crank sensor and plug. It sounds like you have covered about everything else!
