1998 Ranger/B series problem with gem model
Featured Build Threads
Vancouver
BC - CAN
Other
Mazda b2500
Vehicle
Drive
2.5L
I bought a 1998 ranger/mazda b series off marketplace. Pretty much right away ran into problems, the spedo, interior light and transmission stopped working all very close together. Transmssion is automatic and it would just rev higher and higher instead of shifting properly. I took it to a transmission place and they diagnosed a speed sensor problem, this was replaced but transmisson was still locking in low gear. Now they told me it is the general electric model which they took out to verify parts number and get a replacement. They told me they aren't 100% sure that that computer part is what's causing the issue because it has no visible problems and there is one other part it could be.
I'm looking for some advice on what I should do now, do I let them replace the gem model, or do I take the truck back and look into doing it myself? I thought this would be a really easy issue and I didn't mind paying for a shop to do it, but now Im out way more money than I anticipated and my truck still doesn't drive. Its also been almost a month that they have had the truck and no answer as to what exactly the problem is. If anyone has dealt with this issue before and was able to fix it relatively easily please let me know!
I don't believe your GEM will be the problem. But I don't have the exact diagrams for your truck. The vehicle speed signal goes to the PCM and then the PCM and transmission talk to each other directly. I suspect your problem is in one of those places.
The speed signal also branches off and goes to the GEM, cruise control, instrument cluster, etc. But the only way one of those components would cause trouble would be if they are shorting the signal directly to ground.
Thanks so much for the reply, they never told me about the pcm but i'll definitely look for the wiring diagrams and see if I can figure out.
Any chance all of that on the same fuse/relay? I wouldn't think so, but...
Also maybe cab ground bad?
Event Coverage
Featured Ranger Based Vehicle
