Seat Swap Chart that makes it quick and easy to know which Ranger-->Ranger swaps are proven to be quick and easy?
Oaktown
CA - USA
Vehicle
Drive
TL;DR: Really wanted a comprehensive, definitive chart for which Ranger-->Ranger seat swaps are easy-peasy. Could not find said chart. Looks like a lot of folks could find that type of chart real helpful so I started designing it. Attached a mockup/sample here, it'd be great to hear your thoughts, ideas, and feedback. It's a chart. You love charts. More info below if you like. And a chart.
Howdy folks. I've been getting an education about seats, thanks to all you folks. It's been easy to find lots of forum threads talking about this or that particular year model seat possibly going into this or that year model truck, but is there anything like a chart or list you can just look up your truck's year and be able to see right off which years' seats you can just "bolt right in"?
Does something like that already exist around here?
If so, can you post the link? If not, I'm thinking I should make one for 1983 - 2011 and populate it with what little bit of info I know, and then invite y'all folks to add your knowledge and verify that what we've got written down is correct. There's so much combined knowledge among TRS folks that I bet it wouldn't take long to get all the verified-correct info together and put it in the chart.
Is there a wiki (or something like it) around here (or elsewhere) that TRS folks typically use for this sort of thing?
If so, please point me to it and I'll construct the chart there and start adding data to it. If there's no TRS-favored wiki or similar, I can just start doing it here - that'd be significantly more clunky but it'll likely still be doable enough. If anyone's got a suggestion for something that will work better than a forum thread, please fire away.
No matter how it gets built, once it all comes together I'd think the finished chart should be submitted for entry into the Tech Library.
Here's a sample of what I'm thinking the chart would look like (go easy now, it's just a rough mockup to give you an idea and I don't swear by any of the info in it, the end product will look nicer and have only verified-accurate info in it). It'd be great to hear your feedback, thoughts and ideas.
Thanks and happy Saturday.
KD
What happened in 1990? I would be curious about this info myself. I had a 1986 ranger, and guy at work gave me a beautiful 60/40 seat from a later ranger to get it out of his garage. I tried to put it in, the back holes would line up, but the front holes where the seat frame horns curve down were too long and would not line up. I was disappointed to say the least.
Is that what happened in 1990, and a 1989 and down seats will interchange?
@franklin2 Don't take the info in that mockup chart seriously, it's just a "proof of concept", only for evaluating the design and structure of the proposed chart. The data in the mockup should be considered meaningless.
I know next to nothing about seats. But there are many forum threads about the evolution and interchangeability of seats, and tons of folks here who do have real expertise with seats. Don't take anything from me or the mocked-up chart, take a look at the forum threads and ask the actual experts here.
Btw, what do you think about the design and structure of the mockup chart? Does it work for you? Is it easy enough to understand? Any aspects of it that are lame? Any suggestions for improvements?
Anything fits anything if you have enough skill, gumption and the right tools.
I like it. Very easy to see what works and what doesn't. I am thinking the chart will sort of look like your test chart, only the years may change. It would be nice to know that info.
Never seen anything of the like around here, and if you really want to cover all rangers you're introducing a whole lot of complexity to the chart.
Right off the bat it's missing an entire subset of fittment issues, extended cab vs standard cab. Thern there's the solid bench seat trucks, most of which are standard cab. There's also acounting for the fact that solid bench seat trucks are missing seat mounting holes that are required for 60/40 or bucket seats. You could put it right there at the top of the chart and people would still ask about it since it isn;t spelled out in the body.
Then there the endless questions by people looking at the table. "Table says this swap take more work, but what is needed?" "Can you give a pin out of what wires to connect and where?" "Can you hold my hand and walk me through the process?" "Can you just do it for me?"
Inevitably there will be at least a handfull of people come along with something like... "I pulled Cobalt seats out of a 3rd gen extended cab Ranger (where they were mounted with self tappers and blocks of wood) at the salvage yard and they aren't fitting in my 1st gen regular cab, but the chart says they 3rd gen Ranger seats fit. Why not working???" Yes, I pulled that out my a$$, but you'll eventually find something similar referring back to the chart or "TRS said".
Not trying to discourage your taking the initiative, just not sure why anyone would want to take on that headache.
If each cell was a link to a forum post with an explanation (or someone's build thread), that would be hugely beneficial. A lot can be said about taking the time to create such a comprehensive resource.
That is what these boards are all about, interaction between people looking for information, and getting hit with ads all at the same time.
@franklin2 I think you completely missed the point of what I was saying. Go back and try again.
Also, if you're getting hit with ads, you're doing something wrong.
