Rusted A-Pillars
Featured Build Threads
IronTom
Forum Member
Ham Radio Operator
Ontario
Hello all,
Work continues on fixing up my 2003 FX4 Level 2. One of the projects is to remove the rust and paint the A-pillars. In addition, try to figure out why the A-pillars are rusting in the same spot. Did anyone else experienced this problem? Is this a common trouble spot on Rangers? I'll let the forum know what I discover when doing the repair, but checking if anybody has some advice before starting this project.
Thanks,
Tom
Rusted A-Pillars
Rusted A-Pillars
That’s not a common area. You had a water leak either around the windshield, at the rain gutters, or somewhere else at the roofline. Does the truck have a visor or cab clearance lights?
Hi Snoranger,
Thank you for the reply. No the truck does not have a visor or any cab clearance lights.
I suspect the same (water accumulating in the A-pillars). I'm going to run a snake through the pillar to check if there is any blockage.
Tom
if you pop the column trim off it exposes lots of factory holes. if they hold water I would speculate there may be some sound deadening foam in there.
Rusted A-Pillars
I have seen where a replacement windshield was not installed correctly causing issues with the windshield. Not getting the glue all the way around was my experience.
Seems common to me lol. I don't think it has anything to do with the windshield. It's more just poor corrosion protection and design by Ford. Poke at it, get a little handheld sandblaster, and start getting to it. Hopefully it's not too far gone.
  • Rusted A-Pillars
Event Coverage
Featured Ranger Based Vehicle
