Replacement 8.8" Ford ranger rear end.. Aerostar axle shafts? HELP
NYTOSC
Alright, so Ive determined that the trucks rear wheel bearing on the passenger side is bad. It started with a bad seal, but has developed into a full blown destroyed wheel bearing. I am pretty confident that the axle is destroyed as well.
After going to a junkyard, I cant find any full axle assemblies in my gear ratio, so I was wondering if I could simply get a 28 spline axle shaft and put in a new bearing?
What models do I need? I know 93+ are the correct size, and the 28 spline, but what about using a aerostar axle? What about any car ones?
Thanks and any tips would be appreciated!
Please take a pic of the axle shaft when you pull it,,,,,,,,,
