rear end took a dump
mightysonofa
mars
1984 bronco II 2.8 4x4, 4 speed stick shift tranny[ well this sucks ,I get the dura spark done new carb running good and remove all the junk emission crapola then my rear end takes a poo :( so now what ? is it worth the 500 to rebuild or do i find a rear end in the junk yard ? if i get a junk one, what do i look for ? off what years ,make ,vehicle ? also what about the rear drive shaft? any advice please :icon_confused:
oh god don't speed $500 on that rear end.. look up 8.8 swaps.. you can get 8.8's that are (if you're lucky) 4.10's lsd and disc brakes.. and ALMOST bolt in swap. you do have to flip the spring perches and weld on shock tabs. just search 8.8 swap, and look in the tech library
or instead of 4.10's you should be able to get one to match your front gears-- if you're happy with those gears
i have a bunch...come to my place in maine and you can have one for free
I'll have one or two soon. I'll even help you put it in if you bring the truck.
first off, awesome thread title! i say go get a whole axle assembly from the junkyard. look for one that has the same axle code. it should be on the sticker on the inside of your driver door.
