Rangebe...version 2.0
Agreed, looks so sick! But actually, it's still pretty much all Ford, just not much Ranger left. I want to see some sick ramp jamp pics. :headbang:
You make this look so easy... but yet so damn impressive! :icon_thumby:
What do they put in the water up there??? :icon_cheers: Whatever it is, I need some!
Haha thanks boys.
Finally finished this cross-member(s). Sectioned the other side of the joining member, and made it removable as well. Then welded the section to the rear cross member and trussed it...just because I like to over build things :D
Then made templates, cut out the tabs, and welded them.
All bolted and in place. This thing is extremely sturdy.
Also note I got longer bolts in place to account for the support plate. In case anyone is wondering, the stock bolts are M10 x 35 mm, so I grabbed some M10 x 40 and added a washer.
Next on the list is to grab some tube, and get cracking on the cage process...
I really want to know what this thing weighs in at when you are done. Are you using the radius arm tubing for the cage? You truck would be invincible!
Sent from my iPhone
tube will be 1.75" 0.120" wall DOM
been busy with school. Tube will be here next week, have a 100 feet of 1.75" 0.120" wall DOM. Then its tooooooob time.
Toooooooob
Bent up main hoop
Tacked in place
Only had a couple hours to mess with it, and took my time as I didnt want to waste the tube. Now that the main hoop is finished, the rest of the cross bars will be easy. Need to mock up fuel cell/rad/batteries/action packer and then run the rear extension tubes. Wait for updates on the weekend....
Dude this build is straight sick!!! I have been lurking in the shadows and reading here and there but i'm scribed :D
-Lucas
