Question about a little extra lift?
kshack11
Chesapeake VA
So i got this 98 ranger stock with a little bit over sized tires, and i just went muddin for the first time and have found my new hobby. I've been looking into getting a kinda cheap lift so i am getting a 3" body lift. I also came across the torsion lift in the tech library. I want to do that too to give it a little more lift but doesnt that just lift the front? I also heard about adding a leaf spring in the back so i could level out the torsion lift in the front. So i was wondering what kinda spring and if i could just go to a pick and pull and get some for cheap. And how much would one spring lift the back? Also would it be an easy job?
On most Rangers the torsion lift DOES level the front. The rear is fine as is.
With a 3" BL and a torsion twist you can fit 33's, which is as big as the suspension likes anyway.
