need a little answer to this question
wohlrab.daniel
will tires from a 1994 ranger 4x4 ext. cab fit on a 1993 ranger rwd reg. cab?
If the tries are stock size then yes they will. The bolt patterns are the same reguardless os 2wd or 4wd. If the tires are bigger than 235-75 you may have a rubbing problem.
make sure the rims are the same size, my 93 4wd ext cab ranger has p235/75 r 15s on it and my 92 2wd ext cab ranger has p215/70 r 14s on it. the 2wd has aftermarket rims tho, this may be the reason y.
