PlumCrazy's 88 SuperCab 2.3T Build
It's no where as clean as yours but this is what I did to use the stock filter box, I found a 2.9 from I think '88-89 before they went MAF at the junkyard and took the top and hose and made it work, if you look close you will notice I spliced the hose with a hose clamp over the middle, on the inside I put a smoothed piece of PVC to not interrupt flow too much... I needed the 2.9L lid because of the stupid giant air muffler they put on the 2.3L lid that stuck out sideways basically to where the VAM is. This way I kept the stock ducting to suck from behind the grille, I haven't put a gauge to check restriction on the inlet side of the turbo to see if I'm losing anything but it meets my needs... Oh, that iteration is much cleaner than the metal clad drier ducting I used at first :), hey I was young and dumb and it was of course my daily driver...
The first gen EFI airboxes have the inlet on the bottom vs on the side, which should help me keep the inlet away from the hot ass turbo. The 2.9 airbox lid looks like it may be the perfect angle to line up with a straight pipe from my turbo inlet boot, but I think the 2.3 lid I already have may work with the same bend that I am using to the cone filter.
I really just want the airbox because it will make it easier to pull cooler air and give me somewhere to vent the valve cover back into as well as the boost controller vent.....also will look cleaner IMO
Those are pretty much the same reasons I kept the stock filter housing, that and it was easier :)
My valve cover gasket finally showed up. According to the 2.3 gods this is the most robust gasket out there. It fit great and everything but the front cam tower is rigid metal with a rubber over mold.
Replaced the cam seal while I had the truck apart (having the cam pulley off makes getting the valve cover off way easier)
Used my specialty Ford 2.3 timing tool (AKA the dipstick)
Valve cover back on
Went for a test drive to see what else leaks...Valve cover seems sealed, but obviously the valve cover vent still puked because its hooked to nothing still lol....but I think the oil level sensor may be a large portion of the leak. Which is odd because it didn't leak previously when the NA engine was in the truck.
After my test rip I had a pretty big scare. Sounded like a rod knock, but I couldn't confirm/pinpoint it with my stethoscope. It was a clank that matched crank shaft speed, but sounded like it was up front. Started pulling timing covers and anything running on the accessory drive (fan, alt, tensioner) When I found the smoking gun.
The crank pulley had a little slop on the crank....even thought the bolt was tight (I ugga dugga'd it on 30 mins prior)
Turns out...when I stole the crank pulley and the bolt off a 97 engine I should have looked closer at the bolt length. The crank snout must not be drilled as deep on the older crank....The bolt was bottomed out about 1/16" from actually clamping the pulley tight. The keyway on the pulley has a little slop now...but Im not using a crank trigger or anything so as long as it stays tight now Ill be fine
Been there done that on the crank bolt, ran it long enough to shear a key and kill a balancer...
You did make sure to use thread sealant on the cam, right? I don't remember what I got my cam out of but it doesn't have a plug so the dang bolt seals out the oil pressure... that was one of my biggest oil leaks...
This crank pulley already slipped on and off without a puller, so having a loose bolt sure didn't do it any favors. lol
Yup. Cam bolt got a little Gasoila
I think I have the oil leaks 98% contained.
After cleaning up everything and routing the valve cover vent to a temporary catch can stuffed in the fender I was almost certain the oil level switch was the culprit for the leak.
Then I checked what I should have checked on day one.....all the oil pan bolts took nearly a complete turn without much effort. I torqued the pan down back when it was single digit temperatures.... Apparently after the first heat cycle that stiff rubber seal loosened up a good bit.
Put another 100 mi or so on it and the only wetness seems to be all the residual oil weeping out of all the nooks and crannies.
Also was concerned the original Ranger oil pressure switch was bottoming out against the fitting in the head, so I swapped it for a long one.
That was short lived....that switch either has a higher threshold or too much resistance. The oil light never went out. Swapped it back and back in business. Should I put a mechanical gauge on and see what the lifeblood pressure vitals are? Absolutely... but you know what...it sounds good enough for me to not want to know anymore.
Also added a second support to the turbo oil feed line. Used an old valve guide from who knows what, a cable clamp, and a 6mm stud. Originally I was using one of the factory spark plug wire holders but it gave up after a few install/removals. Someday if I run across the 65 mm bolt with an 8mm head I'll swap the stud out. All the ones I found are 8 billion dollars and in a kit. Lol
Got a catch can mounted up just before I took the truck on a roughly 200 mile trip to support my drift car homies.
Ran a -6 hose down to it from the elbow i threaded into the valve cover in place of the factory breather. it clears the tire by a mile and I can drain it by just kneeling next to the truck. After about 200 miles of mixed city and highway in and out of boost I drained about 3ozs out. Not bad IMO and its not trying to push oil out anywhere else anymore.
Truck got lots of love from people at the track and at a few gas stations. Managed to get 20.25 mpg.....not bad for how rich the tune still is.
Been driving this rig on days that are under 85* and its been super solid besides the occasional bridge joint or pot hole that jars the truck and the ignition would cut out (headlights would reman unaffected, but the fuel pump would cycle, the AFR gauge would reset, and idiot lights would cycle). I noticed if I bumped the column or key at all it would cut out.
Pulled the column covers off to replace the tumbler...and found this:
easy enough fix, I re-staked the connector body back to the switch and it was rock solid for a few days.....then I was driving home yesterday and the slightest bump would cut the truck off just like before but wayyyy more sensitive. This was very concerning because I plan to drive this truck over 12hrs round trip next week for Carlisle Truck Nationals. I ordered a new Motorcraft switch and installed, but no change....also bumping the column no longer caused the issue. I started checking every connector and and grommet for a rubbed or loose wire and found nothing. I was jiggling wires and reseating connectors and finally found the cuprit.
Sometimes its the simplest thing...the nut on the ground terminal was a half turn from tight. The small black wire going back is the main ground for the ECU and Fuel pump relays.
Took the truck for a little trip to Carlisle Truck Nationals on Saturday. Didn't take a single picture, but I did catch up with friends, deliver parts, and pickup parts that I made deals on throughout the past year.
Picked some NOS Borla headers for a 4.0. They were stored in a building that had a fire so the plastic bags they were in got half melted on, but no harm done to the headers.
Not sure what I am going to do with them...but here they are.
Truck made the 700 mile round trip without missing a beat. I wish I had messed with the tune more on the drive, but driving in a down pour there for 5hrs straight, then driving home at 3am the next day didn't feel like the ideal time to mess with it.
Still got 17ish mpg running pig rich at WOT. This drive really reminded me how much I need to find the rest of the parts to add wing windows and replace these terrible mirrors lol
Neutral on rev limiter is quite the light show at night
Snagged some decent condition BII buckets this past weekend. Ill have to swap my rails over since the front feet are rotted on them, but no biggy.
Also came with the console that has the information center on it. Not sure how common they are. I don'r know that I will use the console at all. I may build something or just leave it open like my Vic
I also found out that I didnt trim enough of the lip on the passenger side bedside....
I brought home a steel bin that my work was tossing with plans to make a small dump trailer for hauling scrap/multch/gravel. Also had two sets of snow tires in the bin from the big dog manager's cars that were traded in last year...but I guess it was at the expense of a $25 tire on my end. I planned to switch the rears to Geolanders to match the front anyway...I guess Ill do that now.
If only I had a bigger truck or trailer that I could have used. lol
Tire swap complete.
I was going to swap all 4 of my Eagles into this truck, but turns out they have 1/2" less backspace than the Alcoas and would rub for sure, so I just swapped the tires into the Alcoas.
Eventually I will probably swap the 195s off of my white Alcoas on the V8 truck and put those tires on the Eagles and I think they will fit perfectly on the this truck. Or find a pair of 245s to put on the 15x8 wheels I have with the big back space.
i dont understand why you just dont bulge them an inch. it usually looks kewlz too. free anyways and easier than trimming.
explorer swapping requires it kind of too much where it distorts running 10 in slicks, ..but 1-1.5 bulge looks fine to me...most wont even notice it and you can get it just right and maintain truck duty stuff...
i have tried to catch ya a few times when i was heading back and forth from fresno and stone creek from summit and canton
This bed is so rotten and full of bondo that it would blow apart if I tried to bulge it. I probably should have hunted for a pre 93 8.8 In hindsight, but hindsight is 50/50 or whatever.
PM me and we can exchange some contact info. When I'm on the move I don't check here much.
Featured Ranger Based Vehicle
