Oxygen sensors
Featured Build Threads
Chesapeake city
I have a 94 ranger xlt with a 4.0 previous owner removed the o2 sensors and plugged them and removed the wiring for them I need to get them back in because the truck is running rich but I obviously have to run new wiring so if anyone has a wiring diagram or has done this before etc help would be awesome
Welcome to TRS :)
I can't see a reason for previous owner to cut the O2 connector off the truck side, so have a good look for them, they should be behind the intake down low by the firewall, they are round 4 pins each
O2 sensors come with 4 wire lead attached and the round connector to plug into the trucks connector
O2 sensor #1 is the passenger side
O2 sensor #2 is drivers side
There is only ONE wire color difference
O2s are heated, so they have a 12v and ground as 2 of the 4 wires, light blue is 12v, black is ground on both
Then both sensors share a reference ground, orange wire
Then each has its own signal wire to the computer(PCM)
Passenger side, grey <<<<<<<<
Drivers side, red <<<<<<<<
If you find the connectors these 2 wires are the only way to tell which side is which
O2s are on the 2nd diagram but need 1st for where they hook up on computer
Event Coverage
Featured Ranger Based Vehicle
