Most likely I suppose. Looking forward to your next updates!!
I do like the idea of "dripping" a little solder into the cavity as it does make for a very good connection. I have been working on a couple small updates but have not got enough info assembled to post up yet. I am still trying to adjust to the time change and finding the energy to work after dark. It gets dark so early now! Oh well, here is my immediate task list so you can see what direction I am moving and what is coming up in the near future.
Merge battery harnesses and solder wires, starter, ac clutch, ac hp switch.
Merge oil pressure sending wire (DG/WH) to Ranger harness
Attach coolant lines to upper intake with clamps on both ends.
Install various gaskets EGR, etc.
Route vacuum line on driver side.
Install EVAP hose to upper intake.
Bleed clutch system.
Attach alternator wires.
Position cam sensor.
Clean and reinstall oil filter hoses.
Attach starter harness to frame rail on driver side (where secured by wire).
Connect grounding straps. Rear of engine, passenger side frame rail, fire wall, core support, fuel tank, etc.
Check all spark plugs wires.
Check heater core hoses for correct orientation.
Check all vacuum lines.
Fill fluids. Oil, water, power steering, transmission.
Check all wires.
Program ECM, delete PATS, delete rear O2's.
Install battery.
Prime oil system.
****Test start****
Merge upstream O2 sensor, passenger side
Check bolts for front suspension, cab/frame, rear suspension.
Check bolts for trans, engine, fuel tank, headers.
Install Speedometer cable/harness.
Install longer ARP rear wheel studs.
Trim/cut shifter and attach interior trim cover.
Send out to Jim for exhaust.
