- Sep 3, 2010
- Largo, Fl
- Manual
- My credo
- None
All that hard work is paying off, looks like a sheet of glass, as it should...
SVT
wow, this is turning out beautiful... quick question what motor mounts are you using and did you build the adapters your self?
I don't remember seeing your adapter plates, did you post a pic of them and I missed it?
SVT
I cut the excess material off the engine plates and also “clearanced” the inside section of the left side plate where it interfered with the engine block. After the adjustments the plates where test fitted and painted flat black.
