New 15” Wheels. What gear ratio?
235/75-15 and 30x9.50-15 are the same size
When I had my 2010 I went from the 235s to 30s and there was a noticable difference in diameter. Tires ain't ever the same size lol, it's really bad with 4 Wheeler tires. They're generally always an inch under what it says in the sidewall.. some brands are right on.. some brands actually run big.. like wtf lol.
Well, they’re supposed to be the same size and years ago they often were.
I noticed the four wheeler thing myself. Even in the same model tire and size several (85-15) years apart was a huge difference. (Like 2.5 in.)
What is the gas mileage like with a 3.73 gear ratio?
Not sure who you’re asking. My first Ranger (3.0, 5-speed, 3.73 gears, 235/75-15 tires), well, pre-ethanol gas I got 22-25 around town with a bed cover and 28-31 mpg highway. After ethanol gas it was 17/18 around town and 22/23-ish highway.
My 88 Bronco II (2.9, auto, 3.73, 215/70-15 tires got about 18 around town and no idea on highway because it ate a couple valves before I could really figure it out.
I had an identical 89 Bronco II for a few years with 30x9.50-15 tires and 235/75-15 tires that got about 18 around town and 22-ish highway when I got the issues worked out.
My 92 Ranger (4.0, auto, 3.73, 30x9.50-15 tires) got about 14 around town and 18-ish highway and I was still chasing problems when I got clobbered.
My green 00 Ranger that I swapped 3.73 gears in with the 5.0/AWD conversion was getting 12-ish on 31” tires, but that’s also what it got with the 4.0 and 4.10 gears and I was still chasing problems when I took it off the road last year to address a number of those problems. Jury is still out where it settles but I’m also going to a smaller tire/bigger rim with this… adjustment…
I can only tell you for 3.45 and 4.10. I got about 22 mpg with the 2.5 Lima in a RWD regular cab. The terrain and if you drive mostly Interstate, highways, or in town will have an effect as well.
Someone in a more flat area will see better mpg than someone who lives in the Appalachian mountain chain.
Highways that see no more than 55 - 60 mph tend to give the best mpg, with fuel mileage dropping as your speed increases above that.
The tires you use make a difference as well. Stock sized all season or highway tires will give you the best mileage, with all terrains and mud terrains giving you less.
So, as a rough guess, maybe 25 mpg? Supposedly, these trucks can get 30 mpg with a four cylinder.
Since you have a 3.0, I wouldn't expect more than something around 23-24. My 2011 with a 4.0 SOHC saw 23 mpg once, maybe twice, when the stars aligned just right. 20-21 was more what I saw before I went with a bigger, all terrain tire. Now, it's more like 18 - 19, with an occasional 20 mpg.
Just asking anyone. I only get 20 mpg on the highway my B3000 with my 3.45 ratio.
My Splash got 19-21 with the 3.0l and 3.73 gears in stock form before I started messing with it.
Now, I'm lucky to get 17 on a good day with the wind behind me.
With that gear ratio in the rear axle, it makes sense. You would do a bit better with 3.73. Not a massive amount, but better. With the technology these Rangers had put into them until the final production, 20 mpg isn't horrible with a V6.
There are things you can do to get some gains, but there won't be anything massive. One thing to keep in mind about the 3.0, it was designed to run more efficiently at a higher rpm than what most people would consider normal. That is also where the engine better produces it's power. Shift at 3,000 rpm instead of 2,000. It sounds counter intuitive but it works. My Honda CR-Vs were the same way. Even my 4.0 SOHC likes and performs better shifting at around 2,500 rpm than at 2,000. It just takes some getting used to.
Also keep in mind that since the engine is pushing around a brick shaped object, it's not going to get the fuel mileage that a Taurus or Escape with the same engine is going to get. It's a solid, dependable engine. Just not a great match for a truck, even a small one.
When looking at drag coefficient numbers, a ranger is closer to being as aerodynamic as a semi truck than it is a mid sized car. 20 is great on the highway all things considered.. my buddy ran 3.0s for years and never broke 20 mpg.
Aerody- what????
How common is it to find 3.73 rear diffs? I might just get one from the used parts place instead of swapping out the ring and pinion. Is it better to get a ring and pinion and master rebuild kit? I would like to have limited slip but I do not want to pay the money for aftermarket.
3.73 is very common. Limited slip is out there but not as available. Look for the axle tag (assuming it is still there) it will have 3 L 73 on the tag. The tech article section has a section where all the axle codes are listed. That will help you look for one if the tag is missing. Then you can look at the sticker on the door jam and reference the axle code listed there to compare with what you are looking for.
I have been looking in the Tech section to see the codes.
Featured Ranger Based Vehicle
