New 15” Wheels. What gear ratio?
Featured Build Threads
gungfudan
15+ Year Member
⭐Supporting Member
Mississippi
3.0L
N/A
Total Drop
N/A
It has been a while since my last post hello everyone. My friend gave me some wheels and tires off of a 99 Mustang. The tires were an OK condition but one of them ended up developing a bubble probably because they’ve been sitting so long so I got new tires. I got 225/75R 15. I’m looking at changing the gear ratio in the rear end what gear ratio should I go with? I was thinking 3.73. I have a 94 Mazda B 3000. My current gear ratio is 3.43 I believe.
Thank you for calling them wheels instead of rims, the rim is only part of a wheel.
You can look up the diameter and revolutions per mile for the old tires and compare with the 15's. For example: if the old revs per mile was 800 and the 15's show 700, 800/700=1.1428 I expect your current gear is 3.45 if you have a 7.5 so 3.45x1.1428= 3.94. My revolution numbers are random to use as an example, a tire catalog would have more accurate numbers.
These are probably way more complicated than you need...
,but super handy. There are other calculators on that site. Good fun to do some digging and find other useful things. I think it was originally built for construction. (Roof pitch, 2x6 vs 2x8 floors and walls, etc.)
Thank you. Looks like 4.10 ring and pinion.
There are calculators on TRS as well. I've used them lots.
Once you get the overall diameter of the tire (not the wheel. That 15" number is useless) I find this page incredibly useful.
I think you would be happiest with 4.10's, that's what my '97 with a 2.3L has and I like it with 225 70 15, since they're a similar power band I figure a 3L would like them too... it would be easiest to find a whole rear axle...
Going from 3.45:1 to 4.10:1 on the 1998 Ranger I had made a world of difference and the fuel mileage didn't change. It had 225/70R14 tires but it should still make quite a bit of difference with 225/70R15 tires. It think there is only an inch of difference in diameter between the two, if I remember correctly.
Hmmm... 15 minus 14...
cant go wrong with 4.10’s I had a 2.3 with 3.45’s, went to 4.10’s and made a world of difference.
My blue 2000 2wd Ranger (3.0, manual) came with 225/70-15 tires and 3.73 gears. I went to 235/75-15 tires and kept the gears. I was pretty happy with it other than it could have used a little deeper 1st and reverse.
Even with the 4.0 I wish I had a granny gear. Something like a 6:1. I like the way it works currently in low range. If I did the math right, that makes 1st gear 8.432:1.
I really should swap a 302 and ZF5 into my truck. Would solve my torque issues. LOL
3.73s are acceptable up to 235/75/15s which works out to be 29"ish tall. Anything past that would be much better suited with 4.11s
235/75-15 and 30x9.50-15 are the same size
Upcoming TRS Events
Featured Ranger Based Vehicle
