Need some guidance
Edgefevah
Calgary Alberta
So recently I bought a set of P&P heads from a guy off RPS, put them on the engine. Finished getting the rest of the engine together and now she won't start but cranks good. Haven't changed anything else but the different heads.
I aligned cylinder 1 at TDC but just incase I didn't quite do it right what should I do?
I am getting fuel to the FI rail and I have spark, so I don't really know what else I should check?
And just to clarify I only changed the heads and didn't do anything else rest of the motor is stock.
Thanks, Jason
Well put it at tdc of the compression stroke on the #1 cylinder and make sure both valves are closed, I don't see why they would not be though since you didn't take the cam or chain out.
It's an ohv not the sohc right?
