sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
GMRS Radio License
TRS 25th Anniversary
- Mar 11, 2017
- Aliquippa
- State - Country
- PA - USA
- Vehicle
- Ford Ranger
- Drive
- 4WD
- 2.3 EcoBoost
- Automatic
- Tire Size
- 265/70R17
- My credo
- Anything that can go wrong, will go wrong. Plan for it as best you can.
Any ideas about the rear? I put a 9 inch in the Falcon and Mustang, but I know there is lots of talk about an 8.8 out of an explorer. Not sure why, but I could go with one for the right reasons.
And I think a coilover would be a great addition over leaf springs. Any help?
The advantage an 8.8” from an Explorer offers is heavier, 31 spline axle shafts and rear disc brakes.
Only the 2010 and 2011 Ranger axles had rear discs but still have the 28 spline axle. The outer bearings are bigger and have larger axle tubes.
The hard to find FX4 Ranger axles have 31 spline axle shafts and the larger tubes but have drum brakes.
The popularity of the Explorer axle is that they offer both and are a lot easier to find. Plus, with the very limited run on the 2010-2011 axles, there isn’t as much out there for them.
Some have also done a rear disc brake conversion on a regular Ranger axle with Mustang brakes and something else.
It depends on what you are shooting for.
The down side of the Explorer axle is that if you want to stay spring over axle, the spring perches need to moved from the bottom of the axle to the top and shock mounts will need to be added since Explorers use the spring mounting plate to attach the shocks to the axle. The anti-sway bar mount is different as well.
