Need help with rear lighting wiring 1994 Ranger XLT 2.3L manual 2wd
Featured Build Threads
Lubbock Texas
2.3L
P225/70r14
Converting to a flatbed.
Purchased Led light bar.
LINKITOM 40 LED Truck Tail Light Bar
wires are: Red, Green, White, Yellow, Black (5 Wires) out of back of lightbar
Installation instructions as follows:
Black- Ground
Black & Red-brake light
Black & Green- Tail/running light
Black & White- Reverse
Black & Yellow- Turn signal light
My Ranger light wires:
Turn- Orange & Black
Reverse- Pink/Black & Black
Red- Green & Black & Black
Does anyone know how to connect.
Thank you
To properly call out the wiring colors, you list the main wire color first, then the stripe second.
Black with a pink stripe is the Ford reverse light
Black is Ford ground
Orange should be Orange with a lightblue stripe. This is the Ford right brake and turn wire.
The Green should be a Lightgreen with a orange stripe or lightgreen/orange. This is the Ford left brake and turn wire
I looked up the lights you bought. They have a separate amber turn bulb. If your truck does not have seperate amber turns in the rear (some rangers did) you will not be able to hook this amber bulb up.
Event Coverage
Featured Ranger Based Vehicle
