- Jul 1, 2009
- Falcon, CO
- '99 Ranger
- Automatic
- Total Lift
- ORI Struts, front and rear, 14" travel
- Total Drop
- At ride height, 6" exposed on the front and 7" exposed on the back.
- Tire Size
- 37s and 40s
- My credo
- DoL
I've been wanting to build a Ranger for a while, my daughter finally killed hers, so I have a new project... I've been building old Broncos for many years, so will adapt some EB parts into the build.
How it looked when I started:
The tear down has begun...
I started tearing it down June 1st and have made some progress. Kind of a mock-up of how I want it to look when I'm done:
What do I want it to do when I'm done: I love Moab, so Pritchet Canyon followed by Behind the rocks and then drive back to camp. I have a full on buggy for when I want to do 90 across the desert, I want something a little more street-able... And by that I mean mostly legal to drive on the road.
Final specs will be:
Engine is a 351W, MAF EFI with the FRPP harness and an A9P EEC.
Trans is an AODE-W/4R70W with a Quick-4 controller.
Transfer case is a 4 speed Atlas.
37" or 40" tires, 40s are in the mock-up pic.
Custom frame. I have some 2X3" rectube on the mock-up, but it might be easier to just build it out of 1.75" round tube.
Rear axle will be a full-float 35 spline 9" with a True Hi-9 center section, 4.86 gears.
Front axle will be a hybrid 44/60, 35 spline inner/outer, 4.88 gears.
Major questions I haven't answered in my head are interior or exo cage? Or a hybrid of the two? I like an exo to keep the body off the rocks some. Other side of the coin, I'm probably not mounting seats/harnesses to the floor...
Final wheelbase, I'm thinking @120" to keep the break-over angle reasonable.
And a question: Does anyone make a decent set of flares for the front end that will allow me to move the front axle forward @6" and still cover? I'm looking at trimming the fender off so it cuts through the corner right below the bottom corner of the signal lens.
All thoughts appreciated.
Joe
Joe
