- Jun 1, 2024
- mission,bc
- State - Country
- BC - CAN
- Vehicle
- Ford Ranger
- Drive
- 2WD
- 2.9L
- Manual
- Tire Size
- r18 255 45
Shoot ok i wish i could use methanol if there wasn’t one gas station in b.c around lower main land that sells it which sucks.Can get you time and fuel tables... keep in mind I had methanol though. So timing is appropriate to methanol injection. There are non methanol ones posted here by me either in my build thread or in the 2.9 ms thread.
Application dictates chemistry on all engines. Extra viscosity probably doesn't hurt anything. The R&P seems to be good stuff so far tho...
Depending on year, check your cam. Mine was SMOKED when I pulled it. 90s-early 2000s they took the zddp out of oil without reformulating with appropriate molybdenum. Modern sp grade oil fixed this, but not after damage was done. Zddp additives tend to corrode your engine so I'd avoid. Long story. Run SP graded stuff. Should be fine. Cams are notably soft tho. Sometimes lifter tick is lobe wear. Mine was. I made the famous free floating rockers a few years back. Still haven't run them tho. I made a thread on how to do it. Should help with top end oiling with high volume pump.
All cologne pushrod - v4, 2.6, 2.8, 2.9, 4.0 seem to have top end oiling issues. No big deal with intelligent modification. SOHC and DOHC seem to not have issues with oiling.
Much better engine than most understand. Geoff Kershaw won a *lot* of races on one without issue. Twin turbo setup on a BOA/BOB DOHC setup. Insane car. Very fast.
Roger that I was using catalyst Branded oil for the longest time my dad had a pale of it so I just ran it thinking nothing of it now I’m definitely going to be more cautious when looking for oil I had no clue
I think I may have cam wear because I can hear it more notable now I think the collapsed lifter had to do with it I pray it’s not though
When making those free floating lifters was it hard at all? I’m gonna take a look at your posts right now
I also got the dual throttle body’s too just need to put it on they look so sick, eBay seller didn’t even include any of the linkages because why not you know. So I gotta figure something out for that
Sorry for asking a lot of questions I finally get to chat with some one with a similar build to me and see that your still kicking around which is great to see!
