mega squirting the 2.9
blue.bomber
Forum Member
mission,bc
BC - CAN
Vehicle
Drive
2.9L
r18 255 45
just picked up this sweet mega squirt 2 ecu with the 60 pin eec-iv connector was wondering if any one has any ideas on how to wire everything pin location wise and stuff like that. the guy i bought it off of was using it on a mustang so not sure what is backwards compatible probably nothing.
don't mind my absolute mess of a mouse pad it has seen better days lol
The guy to talk to about this hasn’t been on here in awhile, unfortunately. He had tunes and all for it and I got to drive his Ranger a bit at the 20th anniversary get together on here.
go to the megasquirt forum on diyautotune and see if there is an area for the ranger. if not, the ford area should get you some help.
he is around. whether or not he has time to respond...
Ok thanks I’ll try and see what I can do when I get home tonight. Thanks for the help
Not really finding anything on the actual wiring up maybe I’m just dumb and don’t know were to look I’ve check petroleum junkies stuff but he doesn’t mention the wiring up process but I have been reading the manual for the ms2 and says I need to use one ground to the engine block now if I ignore that and just use factory grounds would all be ok? Or should I just gather all the grounds from all the sensors grounding them to the block so I can with have them still run to the connector, I pmd him not sure if he’s gonna respond. I may just send it and go for it why not right can’t be that hard with an actual days of research
I don't know anything about anything, but don't you just want to look up the MS2 pinout, look up your truck's ECU pinout, and match like to like for everything you're using? Signal ground already goes to the ECU.
go to the megasquirt forum....pj ran through there...
of course...he is a genius... but its mega squirt...
you can do it.
i will text him this message...
generally...i am busier that a 2 peckered billy goat.
he is busier than a herd of ten peckered billygoats...
so...yeah.
Ohh I see didn’t know he had one there thanks. this is what I was talking about with the sensor though just gonna see what happens if everything works out with the stock wiring.
you can do it.
Can’t seem to find his profile do you have a link to it?
he dont post there or anywhere....you would have to pay him...
