- Nov 13, 2018
- Canaan
- State - Country
- NH - USA
- Vehicle
- Ford Ranger
- Drive
- 2WD
- Automatic
- Total Drop
- 3"
- Tire Size
- 235/55R16
- My credo
- If you don't have time to do it right will you have time to do it over?
I'd tap on it a few times with a hammer like has been suggested, soak it a couple of times, and get it out even if I had to heat it- though I never have had to heat one in 50+ years. I would also get an actual 3/8 square male socket so you don't break an extension off trying to get it out, the hole the ball lives in weakens the end of the tool. When Fairmonts came out Ford was using water as a coolant for tapping the rear fill hole and then screwing the plugs in while it was still wet and hot so the plugs rotted in place. After twisting off two 3/8 to 1/2 adapters I bought a 3/8 male square socket for 1/2 drive. If you install a fill plug in the rear cover, how do you decided where to locate it? Too low and the rear bearings may fail, too high and it will blow lube out the vent.
