2005 FX4 LvlII Rear Diff Fluid Change
drivenyam
Bedford,Tx
Hey guys! I have done my searching and I have read a LOT, but there seems to be a lot of back an forth on this topic and not a lot of info pertaining to my question directly.
I am changing the pinion seal AND the differential cover gasket plus my truck has over 115K miles on it. So I am looking to change the differential fluid. I have reviewed the tag on the diff and it does say "75W140 SYNTH OIL ONLY". So I get that is the fluid I need, but my question is around the friction additive. I know it's 2oz per all the specs, but which is the better to use? ALSO, I saw Royal Purple that says it has the friction additive in it already. This is the first time I have done a rear diff fluid change on any of my vehicles so I am just looking for a little guidance. Thank you in advance.
Level II has a different style limited slip than a regular truck. It may not require the additive, what does your manual say?
The additive won't hurt either way though.
I don't have my owners manual and I am pretty sure I saw the friction additive info in the tech library on here. Looking for it again to post the link.
Note in the specs given that they mention the Torsen limited slip differential. As far as I know, Torsen only makes gear driven limited slip units, which do not require the additive. The additive won't hurt anything being in there if you get a gear oil with it already in it.
The Torsen does not require friction modifier. As stated above, it will not hurt to add it, but why spend the money?
I've never put it in my Trac-Loc with the 75-140. When I first looked into, I got the impression that was already in every variation of 75-140 at the time. Never had a problem.
Yeah, most 75-140 synthetic oils have the friction modifier in it. The friction modifier is for the clutch driven limited slips to keep the clutches from grabbing hard, which makes for a smoother and quieter operation, but doesn’t let the clutches grab hard, so for a “performance” operation with the clutch driven limited slips, you want no friction modifier.
In your case, you don’t need it because you have a gear driven limited slip so it’s a non-issue
