Left Upstream O2 Sensor Removal
cmcolfax
Forum Member
EMT / Paramedic
Firefighter
Williamsburg
VA - USA
Other
2007 Volkawagen MK5 Rabbit 2.5
Vehicle
Drive
None yet ;-)
Facta Non Verba
Yes, I searched.
Yes, I have the crow foot o2 sensor wrenches/sockets.
Yes, I pulled the inner fender liner.
Yes, I soaked it with PB.
I got the other three done.
Yes, they were kind of a PITA.
But THIS one is šŸ¤¬šŸ¤¬šŸ¤¬šŸ–•šŸ–•šŸ–•
I can get the socket on it.
I can get a ratchet or a breaker bar in the socket.
But there is ZERO room to turn said ratchet or breaker bar.
Any ideas?
12-point wrench?
I’ve used one when it’s been necessary because of lack of room. It usually doesn’t fit on without trimming some plastic off the plug or un-pinning the plug, I’ve done both.
For the really stuck ones I’ll heat the bung on the exhaust cherry with a torch and then wrench like crazy. After it’s out and cool I’ll run a tap through (spark plug taps are the same thread) just to make sure there’s no bits stuck to mess things up on reassembly.
Currently I’m testing out a high temp copper anti-seize compound to see if that helps with keeping them from sticking.
It's already unplugged, IDGAF if I have to clip the wire.
Gonna give my new toy a shot now...
  • Left Upstream O2 Sensor Removal
I used hi-temp copper anti seize and ran a thread chaser thru on the other three. šŸ‘
I should probably get one of those
What is this sensor that plugs into the side of the transmission?
It looks like it is held together by a c clip.
If I could get that wire out of the way I would have a little room.
Vacuum line maybe? Vent line? Not really sure offhand. Hopefully someone else knows, I can’t really go poke at anything at the moment and try to figure out what it is.
This is my first time using it! šŸ¤·ā€ā™‚ļø
I’ve been using an oxy/acetylene or oxy/propane torch for the last like 20 years, but I’ve seen people use those induction heaters and I know that sometimes a torch either doesn’t really fit or there is lots of stuff that can be inadvertently melted nearby where you need to use it where that wouldn’t be as much of an issue with the induction heater
I've heard that they aren't necessarily all they're cracked up to be apart from some rather niche situations where using flame is an absolute no-go.
Let us know how hot she can get things cookin.
I've always wondered about the effectiveness of getting reeeeeeeally stubborn crap broke free by getting it ripping hot and then immideately hitting it with some 'bolt-freeze' or whatever it's called. Id imagine going from hot AF to cold AF within a second or two would help stuff crack itself loose rather well..
That does work too. I’ve tried it. One thing I do love about a torch is if heat and/or heat to cold doesn’t do the job, there’s a handy little magic lever on a torch that reduces metal to liquid. Can’t be tight if it’s a liquid.
